Quantcast Spun a rod bearing.... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Spun a rod bearing....
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 04-20-2007, 07:55 PM   #1
perley03
Well last night I was coming home from work and I noticed this knocking noise when I pulled into the driveway. I shut it off and came on here and searched for a bit and thought it was lifter tick. So today I went and bought 10-40w oil and a new filter and put that in, and it quited it down, for a bit. I drove to work and coming home it got louder and louder. I called a friend (mechanic) and he came over and listened to it and it's definatly rod knock. We pulled the plug wires one at a time and #2 is the culprit. $53 for new bearings (I ordered standard and +.010") and tomorrow we are going to tear into it at his shop and find out what is wrong. I hope that I can just fix this the easy way, as I'm broke (as usual) and have no money for a replacement engine.
By the way, the engine has 153,xxx miles, and has good oil pressure (above 60psi), and today when I drained the oil there was no shavings in the oil (weird). Has anyone ever had this problem on their 2.5L??
perley03 is offline   Reply With Quote
Old 04-21-2007, 06:09 AM   #2
Sbeltinc
I bought a 99 TJ with the 2.5 and the #3 piston had exited out the side of the block @ 88k miles. Rod and pin where still attached to the crank though and it ran :-)
Replacing the bearing on a rod that already spun one is a bit risky IMHO but I too would try it if on a budget.
My used TJ parts for sale at:
http://roadracing.20m.com/photo_1.html
Sbeltinc is offline   Reply With Quote
Old 04-21-2007, 08:08 AM   #3
wcurleyq
The crank will need to be turned. so, there went the budget repair.
06 TJ / 4ltr / Auto / 4" Rough Country X / 5 33x12.5x15 M/T Baja MTZ / AA SYE / Tom Woods Shaft / Herculined Tub / Hand Throttle / OBA / AntiRock / Rusty's Crossover Steering / Rock Hard Bumper Carrier / Cheap high-lift jack / Fire Ext / CB
wcurleyq is offline   Reply With Quote
Old 04-21-2007, 09:51 AM   #4
TJ_Firefighter
yep.....there's not reallya cheap fix for anything in that area
1999 TJ
4.0L
2" BB 2"BL, ProComp Adj. Front Track-bar, SkyJacker Hydro 7000 shocks
33x12.50 Dunlop RV
[B][COLOR="Wheat"]Kahki Jeep Club Member #42[/COLOR][/B]
[COLOR="White"][B] U.[COLOR="Orange"]S.C.G[COLOR="White"]. J[COLOR="Blue"]ee[COLOR="White"]p Club Member #1[/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/B]
[COLOR="Red"][B]Firefighting Jeep #2[/B][/COLOR]
Soon to come: HomeFab Rockers
TJ_Firefighter is offline   Reply With Quote
Old 04-21-2007, 10:20 AM   #5
littleman66
now would be the time of thinking about doing 4.7 stroker
just a thought
edit: never knew it was a 2.5. sorry
2001 60th Anniversary TJ.
2" BB. 31" Goodyear Wrangler MTR's
Dana44 LSD. front Aussie Locker
homemade rear bumper with hitch, two recovery points
dual battery. 1750 watt inverter
Dukes of Hazard/Dixieland horn. Neoprene seat covers
littleman66 is offline   Reply With Quote
Glock Forum
