Quantcast Spun Axle Tube - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Spun Axle Tube
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 05-26-2008, 05:31 PM   #1
cajunjeep
Spun Axle Tube
I just figured out that I have even more damage from apoast run. I seem to have spun an axle tube on my rear Dana 44. I have never done this kind of damage before. Anyone know just how to go about fixing this?
Thanks,
Robbie
2003 Jeep Grand Cherokee Limited 2wd-Daily Driver
1985 Toyota 4-Runner on 1-tons and 39.5" IROKS-Wheeler
cajunjeep is offline   Reply With Quote
Old 05-26-2008, 05:40 PM   #2
mrblaine
Brake Wizard
mrblaine's Avatar
Thanks,
Robbie
If it's just spun with no other damage, you can do a few things.
Spin it back, clean out the rosette welds as best you can and re-weld. Then you can weld the tube to the end of the diff casting where it joins the tube.
Bear in mind you will need to pull the gears and re-seal the end of the tube where the carrier bearings are and the gear set-up should be re-checked upon re-installation of the carrier and ring gear.
I am Savvy
I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Old 05-26-2008, 05:42 PM   #3
never monday
You probably have a damaged control arm also, have a look.
Get Savvy
never monday is offline   Reply With Quote
Old 05-26-2008, 06:52 PM   #4
jason m
i did the same thing to my 14 bolt http://s150.photobucket.com/albums/s89/420willys/?action=view&current=Image014-1.jpg . i did jack the tube back into position buy just putting a bottle jack on the pinion and a chian around the axle to the frame. i was able to fix this housing but only kept it for the reast of the seasion. now my new 14 bolt is 4-linked and has looks like this http://s150.photobucket.com/albums/s89/420willys/?action=view&current=0611072315.jpg and this housing has the tubes welded to the center section http://s150.photobucket.com/albums/s89/420willys/?action=view&current=0623071337.jpg . i never removed my carrier when i fixed the old one, jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
jason m is offline   Reply With Quote
Old 05-26-2008, 07:25 PM   #5
raskull
*DROOL* at your new 14bolt!
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (pic)
http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery
Custom front bumper build
Custom rockers build
My build thread
raskull is offline   Reply With Quote
Old 05-26-2008, 08:36 PM   #6
cajunjeep
Yep, already repaired it. It is what appears to have caused the damage. When it went, it basically forced the tube to spin inside of the center section.
Old 05-26-2008, 08:45 PM   #7
never monday
same thing happened to my 35. Did the side opposite the failure twist?
Twist it back in place with what ever combination of straps, chains and heat needed. After heating the housing we welded the tubes to the housing and trussed the axle.
Get Savvy
Old 05-27-2008, 07:49 AM   #8
cajunjeep
looks like I'm going to try to twist it back into place and see what happens. Worse comes to worse, I need a new housing. thanks for all the help.
Glock Forum
