spring retainer clip question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > spring retainer clip question
Poison Spyder to donate 10% of Memorial Day W/E Sales to RNEW JK All Terrain Bumper and X-Style Stryker Stinger - 20XJ guys, clock your transfer case!
Unread 08-20-2009, 01:05 PM   #1
mmarmouz
Hi,
I was installing my 4" lift yesterday, and when removing the coil springs, it say to remove the driver side coil spring retainer clip located on the back side of the axle coil seat.
the thing is i own my tj since day 0, and i know it has never been modified, and you know what, I DON'T HAVE THAT RETAINER CLIP.
Is this normal or not ? should i be ok without it anyway ?
I have a 2.4L 2006 TJ SE
Thanks !
mmarmouz is offline   Reply With Quote
Unread 08-20-2009, 01:08 PM   #2
Dravintoad
Very common, Nothing to worry about.
Mine only came with the drivers side. I think in the later years they decided they weren't necessary
You can buy them from the stealership if it would make you feel warm and fuzzy
Nothing to see here.
Move along.
Dravintoad is offline   Reply With Quote
Unread 08-20-2009, 01:20 PM   #3
gabriel05
No worries. Dravintoad is right.
Black Jeep Society Member
gabriel05 is offline   Reply With Quote
Unread 08-20-2009, 01:21 PM   #4
mmarmouz
I don't have on both driver and passenger side ! Think 2006 Model do not have then.
I am just worry because i am installing a JKS Discos with the 4" lift, so can my spring pop out of it place with a full flex when offroading ?
Unread 08-20-2009, 01:36 PM   #5
mmarmouz
anyone can make me confident and tell me i will not loose my spring when offroading ?
Unread 08-20-2009, 02:17 PM   #6
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
i didnt have a clip on either side. still dont. nothing to worry about.
Unlimited04 is offline   Reply With Quote
Unread 08-20-2009, 02:32 PM   #7
mcg311TJ
My 06 Rubi doesn't have them. It was easier to do my lift, I'm not mad
mcg311TJ is offline   Reply With Quote
Unread 07-12-2012, 01:34 PM   #8
Sdavidf
My Spring drops out.
Sorry I know this is a really old thread but I thought I would give my two cents.
My TJ also came with no clips, however I am in the market for some.
Whether or not you need spring retainer clips depends on a lot of factors in the type of lift you have. I have pieced together a 2" lift with all after market adjustable control arms and long shocks. The result is that I have crazy mad axel articulation. With the sway bar disconnected my axel will actually drop 2-3" past the fully unsprung hight of the springs. This is no problem on the top because the bumpstop keeps the spring aligned. However this past weekend while wheeling I found my driverside spring resting securely on the swaybar bracket. Two quick minutes with the Highlift and we were back down the trail, but I am looking for some spring retainers to solve the problem.
If your interested Rusty's has some for sale for $10.
Sdavidf is offline   Reply With Quote
Unread 07-12-2012, 01:35 PM   #9
Sdavidf
Here is the link for Rusty's clips.
http://www.rustysoffroad.com/rustys-...iner-clip.html
Unread 07-12-2012, 01:52 PM   #10
biffgnar
biffgnar's Avatar
And that amount of flex is useful how? How much down pressure/traction are you getting at that point? With those long shocks and that much down travel how much uptravel do you have? Your jeep to do with as you please, but personally I'd be thinking about some things other than a couple stupid clips.
2013 NORRA Mexican 1000 - Co-Driver #199
2012 King of the Hammers - Hammerking Productions "Intern"
HELP KEEP JOHNSON VALLEY OHV AREA OPEN: http://www.savethehammers.org/
biffgnar is online now   Reply With Quote
Unread 07-12-2012, 01:56 PM   #11
mdm
Farm Wheeler
I've got to agree with this.
If your wheel is dropping far enough to unseat the spring you need to be doing something to limit the droop rather than fastening the spring in place. Limiting straps come to mind as a viable solution.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote
Unread 07-25-2012, 09:39 AM   #12
Sdavidf
I wasn't sure how it would work out either. However I found that it really does keep traction very well. The weight of the axel and wheels is significant.
As for upward travel the shocks I have are designed for a 2"-4" lift and I have 2". So when I say they are long I mean I am on the bottom side of the recommended range. So there is no limit to the upward movement.
The real difference maker in downward travel comes from the aftermarket control arms. Stock arms are usually the first thing to limit travel on stock vehicles. The aftermarket arms are tubes and can adjust from stock hight to 6" lift so they stay well out of the way.
The other reason I need clips is because the bar stock the springs are made with is thicker than stock, like rubicon express springs. So the springs don't fit all the way into the little hole on the spring mount. I actually had one rotate on me the other day on a bumpy paved road. So the spring clips are necessary weather I get limiting straps or not.
Unread 07-27-2012, 10:47 PM   #13
Rubiman805
Next time you go to the junk yard nab the clips of a grand Cherokee. You see them all over the yards.
Rubiman805 is offline   Reply With Quote
