Sprayed Cam Pos. Sensor w/ H2O and now it won't start... Need HELP!! - JeepForum.com
post #1 of 5 Old 01-17-2010, 04:36 PM Thread Starter
ElJaynocibuR
I've been having intermittent drivability issues when it's raining so I was out in the driveway trying to diagnose the problem.
I sprayed the hell outta my brand new crank pos. sensor, and it ran fine.
I then sprayed the cam pos. sensor and the "distrubutor looking apparatus"(?) and then the jeep died.
I thought no big deal, once it dries it will be back to normal, but it's dry now and it won't run at all. It will turn over just fine, but doesnt fire off.
Any suggestions?
I took off the black cap on the "distrubutor looking apparatus" and everthing looked fine (no water, and no metal shavings)
2006 LJ Rubicon=4" lift, 305/70/16 Mickey T.'s MTZs, etc...
ElJaynocibuR is offline
post #2 of 5 Old 01-17-2010, 09:24 PM Thread Starter
ElJaynocibuR
I went out several hours later and it started....I hope a new cps fixes the problem.
post #3 of 5 Old 01-18-2010, 06:54 PM
herbiehind
wd 40 is awsome at displacing water . water displacement 40 . spray the crap outta the electrics next time before firing up .
herbiehind is offline
post #4 of 5 Old 01-18-2010, 08:41 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
You do understand that the camshaft sensor is the "CPS" and the crankshaft sensor is the "CKP" right?Please explain again what you sprayed?
GOLENJEEPTJ is offline
post #5 of 5 Old 01-19-2010, 09:03 AM Thread Starter
ElJaynocibuR
I sprayed both the CKP and the CPS. I started by spraying the CKP, nothing happened. I sprayed the CPS and almost instantly the jeep died and wouldn't start.
It eventually dried out and started again. It ran fine the rest of the day and the next morning, and then it left me stranded on my way home from work. (It wasn't raining and should have been dry)
Broken Oxygen sensor wire causing engine not to start? Tedje TJ Wrangler Technical Forum 16 01-09-2009 01:30 PM
My 2.5 takes a while to start, is it the cam sensor or crank sensor!! Divebum TJ Wrangler Technical Forum 9 12-24-2008 01:38 PM
Replaced Crank Sensor now it won't start. Erik T. TJ Wrangler Technical Forum 11 12-11-2007 07:19 AM
Help! o2 sensor cause no start? Mfox98 TJ Wrangler Technical Forum 12 09-25-2007 12:01 PM
Cold Start sensor BASSPLAYER1 YJ Wrangler Technical Forum 9 12-21-2006 05:33 PM
