Splitfire Plugs vs. Standard Plugs - JeepForum.com
post #1 of 9 Old 11-18-2003, 10:09 PM Thread Starter
Alphadux
Alphadux's Avatar
Okay, so is there really a difference in using Splitfire Plugs or even Splitfire Triple Platinum Spark Plugs as opposed to any regular run-of-the-mill spark plug? Thanks.
Black 2000 TJ Sport, 4.0 Manual, Hard/Soft Top
AFE Intake, Poweraid Throttle Body Spacer
Banks Torque Tube Headers/Cat-Back Stinger Exhaust System
Dana 44 's, 4-wheel discs
Alpine CDA 9815 MP3/Infinity Kappas 4x6"s, 6 1/2"s, 12"s/ 800watt sounds
4" Superlift 33X12.5 BFG A/T KOs on 15/8" AR Wheels
Warn 9.5 ti Winch is next!
Vampire Jeep Owners Club #13
Black Jeep Club Member #69
Follow Me To Certain Death Jeep Club Member #31
BIG GUNS AND JEEP OWNERS OF AMERICA CLUB FOUNDER
Alphadux is offline
post #2 of 9 Old 11-18-2003, 10:17 PM
doorocks
doorocks's Avatar
[QUOTE=Alphadux]Okay, so is there really a difference in using Splitfire Plugs or even Splitfire Triple Platinum Spark Plugs as opposed to any regular run-of-the-mill spark plug? Thanks.[/QUOTE]
The answer, in my recently educated opinion, is no for the most part.
I recently used the Bosch +4's, basically the same "gimmick" as the splitfire plugs. After several debates, one with Jerry B. , I decided to try the single platinum plugs by Autolite.....which many here use.
I have better results with the singles , than I did with the +4's. I also have a FireControl Iginition, which does make a difference and that is true.....but as for the plugs, just stick with the single platinums by Autolite or similar make...take it from a recent turncoat from the "splitfire" hype.
Oh and prepare yourself, the debate will begin shortly. Have plenty of popcorn and soda.....I mean beer.
Steve
LIFE IS TOUGH ENOUGH ALREADY, IT'S EVEN TOUGHER WHEN YOU'RE STUPID.
RE 3.5 and all kinds of other relevant goodies, you know winch and stuff.
Life is like walking into the No Chance Bar full of Future Darwin Stories........
More mods than a hillbilly's set of teeth..
doorocks is offline
post #3 of 9 Old 11-18-2003, 10:23 PM
blupupher
blupupher's Avatar
blupupher is offline
post #4 of 9 Old 11-18-2003, 10:31 PM
thephantum
thephantum's Avatar
1997 XJ Cherokee
I agree with you...just use the correct heat range plug and don't bother with the splitfires or any of the gimmicky plugs. I tried the Splitfire triples in my Camaro. I put them shortly after I first installed the engine (I ran with AC/Delcos first)...no difference in performance, MPG, etc. When I installed the MSD I ran with the splitfires for awile and then went back to AC/Delco's...again no difference (there was a difference going to the MSD, but none upon switching plugs).
I just use Champions (in our Jeeps) and AC/Delco's in the Camaro.
My $0.02
Steve
thephantum is offline
post #5 of 9 Old 11-19-2003, 12:24 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Splitfire sparkplugs are junk.
Getting
Jerry Bransford is online now
post #6 of 9 Old 11-19-2003, 12:49 AM
jandoaudio
I am currently running Bosch Platinum 4s and they perform about identical to the copper champions that were in there before. The spark plug choice isn't that important in a stock jeep motor, I would just run champion or ngk coppers and change them every 10k miles if I was to do it again. The copper plugs produce just as good if not a better spark than platinums, they just don't last as long.
Spark becomes important when you are running a high performance motor and trying to avoid blowout. I run ngk coppers in my twin turbo stealth because that is what has proven to give the least blowout problems at high boost levels, they give better spark than platinums or iridiums, you just change them 3 times as often
Cheap, Capable, Reliable.......
You can only have two
jandoaudio is offline
post #7 of 9 Old 11-19-2003, 01:53 AM
iroc22
iroc22's Avatar
Copper will always produce a better spark, which makes more power. Copper has better conductive properties than platinum and iridium.
Split Fire's aren't junk plugs, they just aren't worth the money.
iroc22 is offline
post #8 of 9 Old 11-19-2003, 02:13 AM
KILLERtj
KILLERtj's Avatar
I got Bosch +4's in my Jeep and I cant notice a difference.
Peace Out
KILLERtj
Red Jeep Club #5
Vampire Jeep Club #6
02 Wrangler SE, Ford 8.8, 4.88's, Tera-Flex S4T, 35" MTR's
Faster than a Ferrari on rocks!
KILLERtj is offline
post #9 of 9 Old 11-19-2003, 07:35 PM
kaybone
Champion Truck Plugs #4412
kaybone is offline
Need Spark Plugs - Can't find the Champion Truck Plugs #4412 2004JeepTJ TJ Wrangler Technical Forum 29 09-17-2011 09:37 PM
splitfire plugs? urstolendesire TJ Wrangler Technical Forum 16 01-11-2009 07:44 PM
Removing Block COOLANT Drain Plugs. Not the standard 3/8th size. Delta347 YJ Wrangler Technical Forum 6 01-01-2009 01:53 PM
splitfire plugs - any good or just hype? beachkat YJ Wrangler Technical Forum 10 03-17-2008 07:04 PM
Splitfire spark plugs? Jaxbrian TJ Wrangler Technical Forum 19 02-15-2006 12:26 AM
