Speedometer stopped working after "light" off-roading... - JeepForum.com
post #1 of 8 Old 04-18-2010, 06:10 PM Thread Starter
shdwtek
My speedometer died today after doing some "light" off-roading. I'm not sure if I broke something, or if it was coincidence, since it seems to be a common problem. All the other gauges work fine, with the exception of the shift arrow light. It comes on even when I'm in 5th gear. I pulled the cluster, and clean the connections. No luck so far. Any suggestions?
Jeep is a 2001 Wrangler Sport. Also.. ever since I had the Jeep, the 4wd lights never worked.
shdwtek is offline
post #2 of 8 Old 04-18-2010, 06:22 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Check sensor plug at transfer case first.Could be torn up gear or bad sensor gear plugs into.
GOLENJEEPTJ is offline
post #3 of 8 Old 04-18-2010, 06:47 PM Thread Starter
shdwtek
Thank you, I'll check it out.
Is it possible I could have broke it somehow offroading? Like a tree branch or something?
shdwtek is offline
post #4 of 8 Old 04-18-2010, 06:58 PM
GOLENJEEPTJ
Only if you wacked the rear of transfer case and maybe hit the plug at sensor? but I really doubt that.Good luck let us know.
post #5 of 8 Old 04-18-2010, 07:05 PM Thread Starter
shdwtek
Ok. I look around tomorrow when it's light out. I did hear some noises here and there, like I kicked up a rock, or branch or something. ...Dragged a pretty big branch at one point.
Sorry for any stupid questions. This is my first Jeep, and I haven't had an issue like this before.
shdwtek is offline
post #6 of 8 Old 04-19-2010, 10:31 AM Thread Starter
shdwtek
Well, I checked underneath, and it looks like it broke off. Now it wants to stall at a stop unless I give it gas, and then it's ok.
shdwtek is offline
post #7 of 8 Old 04-19-2010, 12:33 PM
gtstricky
Should be an easy fix. There is only one bolt holding the speedo gear into the transfer case. Unbolt it and pull everything apart. See what part is broke and get a new one. Probably $20 - $60 and about 30 minutes total.
Must reads for new TJ Owners:
gtstricky is offline
post #8 of 8 Old 04-19-2010, 12:45 PM
GOLENJEEPTJ
Your stalling could be a dirty IAC valve on your throttle body.You could pick up a can of throttle body cleaner at the parts store for under $10 bucks.Follow the directions. Is your plug still in good condition that goes to the speedometer sensor?
Help! My Speedometer Stopped Working and Check Engine Light is On Too 95GreenWrangler YJ Wrangler Technical Forum 22 04-22-2010 06:08 PM
Brakes are spongy, "BRAKE" light is on when stopped, flashes when moving rsoby TJ Wrangler Technical Forum 13 10-09-2009 10:40 AM
Speedometer stopped working MaxPower49 TJ Wrangler Technical Forum 0 09-25-2009 08:01 PM
Speedometer stopped working....... NewhampshireYJ YJ Wrangler Technical Forum 1 01-01-2008 09:46 PM
speedometer not working after off roading jeepYJ.TO YJ Wrangler Technical Forum 6 04-06-2006 01:28 PM
