Speedometer issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Speedometer issue
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 05-19-2015, 01:59 PM   #1
b1bjetmech
Speedometer issue
Hey guys - I have a weird issue with my speedometer that I hope maybe someone can help me with. I have a 2000 TJ, with an NP231 Mega Short Slip Yoke Eliminator (SYE) Kit with Speed Sensor. The speed sensor was a gear drive, and now it is a magnetic speed sensor with a tone ring. After installing the SYE, the speedometer was off by a bit, and it also fluctuated up and down about 20 mph while driving - which caused the transmission to upshift and downshift with the speedo changes. I installed a Dakota Digital SGI-5 interface on it about 6 months ago, and voila - everything worked! I got the speed stabilized, and I also got it reading accurately. Now fast forward about 6 months to about a month ago, and now my speed is fluctuating again, and it isn't at all consistent. I talked to Dakota Digital folks, and they suggested that the I measure the AC output of the speed sensor coming off the SYE housing. I was never actually able to get a good read on it, but I assumed since my SYE was only about 9 months old that it was probably ok. Maybe it is the culprit, but it is $120, and I don't really want to spend that kind of money just for trouble shooting. Have any of you experienced a speed sensor failure from the Rugged Ridge kits, or had similar issues with either the Dakota Digital interface? I've also read that it could be the PCM in the Jeep? I am to the point that I will probably have to take it to an auto electrician to troubleshoot it - unless some of you geniuses can help me.
Thanks!!
b1bjetmech is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 03:08 PM   #2
KCBrewer
Make sure the yoke is torqued TIGHT. I have the JB SS SYE and the instructions call for 200 ft lb on the yoke nut, and mention the speedo being erratic if not properly torqued. The tone ring depends on this to keep it from moving.
98TJ-4.0/OME/8.8/HP30/4.10/Locked/33s
53 Willys Pickup- 5.0/NP435/D18/Warn OD/D44/D25/4.27/31s
KCBrewer is offline   Reply With Quote Quick reply to this message
Unread 06-08-2015, 05:53 PM   #3
b1bjetmech
Well I finally figured out what was wrong with my speedometer - and KCBrewer - you were on the right track! I ended up having to add a washer between the yoke and the tone ring. Apparently, the yoke doesn't quite contact the tone ring enough to lock it firmly in place, and Rugged Ridge is aware of this issue. When I contacted them about it, they said the fix was to install a 1 1/2" ID x 2 1/4" OD x .080" washer. So have any of you out there with a Rugged Ridge Mega Short SYE had the same problem? If so - go to your local True Value hardware store (or similar) and pick one up for under a buck! Easy fix! (once I figured out what the heck it was!)
So now I have a spare Dakota Digital SGI-5 interface if anyone is interested in it! I will sell it for $50 plus shipping. It works fine, I just replaced it to trouble shoot the problem, and it wasn't the problem!
Unread 06-12-2015, 10:41 PM   #4
john02tj
Sounds like my issue as well looks like i will have to try this.
2002 Auto 4.0 TJ/ Ford 8.8 rear D30 e-locker upfront with a ton over other fun stuff!
john02tj is offline   Reply With Quote Quick reply to this message
