Speedometer Disconnected..please help - JeepForum.com
post #1 of 3 Old 07-08-2010, 03:27 PM Thread Starter
bp96
I just recently purchased a '99 Wrangler, auto, 4.0L the guy I bought it from said he had disconnected the speedometer because of the larger tires making it off. The speedometer/odometer currently do not work and the check engine light is on(because the speedo is disconnected). I thought that he had just taken out the speedo gear out. Once I got it home I checked it the speedo gear was still in place and was still connected. I havent been able to contact the previous owner and he lives about 8 hours away
I haven't seen any cut wires or any thing....so I was wondering what specific things/areas to check and where to find them to get the speedo/ odometer working again.....
bp96 is offline
post #2 of 3 Old 07-08-2010, 04:15 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Is the speedometer plug clocked correctly in the TC?
Do you have a OEM FSM?...
Knuckelhead is offline
post #3 of 3 Old 07-08-2010, 05:21 PM Thread Starter
bp96
I have a haynes FSM and doesnt really go into great detail, I installed the gear using an online guide from 4x4explorer.com. Is there any other way the speedo could be disconnected other than the transfer case( as far as connectors go)
bp96 is offline
4.0 , tj , wrangler , speedometer , disconnect
Speedometer Disconnected..please help bp96 YJ Wrangler Technical Forum 2 07-08-2010 08:34 PM
im disconnected now ??? 2005X TJ Wrangler Technical Forum 34 01-16-2006 05:04 PM
going disconnected? coorsmgood TJ Wrangler Technical Forum 24 11-07-2005 08:04 PM
disconnected 97sahara TJ Wrangler Technical Forum 2 06-15-2003 05:01 PM
disconnected or no? cptyarderho TJ Wrangler Technical Forum 4 06-25-2002 09:39 AM
