Speedometer Calibration - JeepForum.com
post #1 of 24 Old 09-17-2005, 09:32 PM Thread Starter
Linda or Greg
Linda or Greg's Avatar
I just compared my speedometer to my GPS. When the speedometer says 60 - the GPS says 65. The work seems simply enough -http://www.4x4xplor.com/speedo.html - but somewhere I think I read that on an '05 TJ the fix is electronic and not mechanical. Anyone know for sure?
I'm driving a 6 speed, 6 cyl, 31s and a 373 rear end.
'05 TJ High Country Daily Driver
Linda or Greg is offline
post #2 of 24 Old 09-17-2005, 10:12 PM
Rocky529
Rocky529's Avatar
Only the Rubicon and Rubicon Unlimited are electronic. Any other TJ has speedo gears just like any other year TJ.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 24 Old 09-17-2005, 10:32 PM
slopoke101
the dealer told me my 2005 wrangler x had electronic speedo and they had to reprogram computer when I put bigger tires on it.
slopoke101 is offline
post #4 of 24 Old 09-17-2005, 10:37 PM
Rocky529
Rocky529's Avatar
Interesting. Another user here had a '05 that had to be programmed but I think it is because he said he swapped transfer cases or something. He said that all other '05s are the same as prior TJs.
Rocky529 is offline
post #5 of 24 Old 09-17-2005, 10:59 PM
slopoke101
I must investigate this further.
post #6 of 24 Old 09-18-2005, 09:25 AM
El Jay
El Jay's Avatar
1995 XJ Cherokee
The dealer told me the same thing about my 05'. Fast forward a week, when I went to make an appt to get it done they changed their tune to "Oh we can't fix yours through the cpu". After I asked them how do I recal. my speedo they were at a loss, they swore I couldn't swap out the speedo gear. Basically telling me I was SOL.
I got the part number I needed from the speedo chart, when I went back to order it, the effin service guy tried to tell me it wouldn't fit because it was for a cherokee?! I had him order it for me any how ($9).
10 Minutes of work under the jeep and I was good to go. To make a long story short...The Jeep dealer here in Crestview, FL is full of morons, only Rubi's need to get hooked up to the computer, and you can fix your speedo for about 10 dollars and 10 minutes of work
1995 Pearlstone Cherokee, 4.0L Auto
2" BB, BFG/AT 31x10.50
El Jay is offline
post #7 of 24 Old 09-18-2005, 11:56 AM
slopoke101
thank you, they wanted 101 bucks to reprogram.
post #8 of 24 Old 09-18-2005, 04:26 PM Thread Starter
Linda or Greg
I crawled under my jeep ('05) and pulled the speedometer gear out of the transfer case. Shoulda done that earlier. It is a mechanical fix. The gear was a 36 and I need a 33. I guess that's the problem. Now I have to go to the dealer - I hate that.
post #9 of 24 Old 09-18-2005, 07:52 PM
Jeepster Tim
1981 CJ7
I have an 05 Unlimited and I just changed the gear - takes 5 minutes
Jeepster Tim is offline
post #10 of 24 Old 09-18-2005, 08:03 PM Thread Starter
Linda or Greg
My tires are 31s. They physically measure 30" high. I should use the 30" measurement in determining what gear to buy - right?
post #11 of 24 Old 09-19-2005, 08:09 PM Thread Starter
Linda or Greg
I bought the pinion gear based on the measured height of my tire - 30" - even though the tire is sized as a 31. I checked it against the GPS and it was exact. If I had installed the pinion gear for a 31, I would have still been off. It's tricky getting that gear out and not tearing the O ring.
post #12 of 24 Old 09-19-2005, 08:30 PM
orangetj05
orangetj05's Avatar
my 2005 has a speedo gear in it im sure yours does to.
2005 TJ 5.7 HEMI, Caged, Locked, Long armed, Stretched, Air shocked, Cromoed, Running 37 Irocks
orangetj05 is offline
post #13 of 24 Old 09-19-2005, 08:43 PM
SGT Superman
SGT Superman's Avatar
How do I know what R & P I have?
Now you know, and knowing is half the battle. G.I. Joe!
Green Jeep Club Member #174
GO COUGS!
SGT Superman is offline
post #14 of 24 Old 09-19-2005, 08:48 PM Thread Starter
Linda or Greg
On my '05, it's on a metal tag attached to the rear diff. It starts off 3.73 followed by other numbers.
post #15 of 24 Old 09-22-2005, 04:37 PM
SGT Superman
Can you post a pic of this? I think I know what you are talking about, but my tag is warn and its hard to know if I'm looking at the right numbers, thanks
GO COUGS!
Speedometer Calibration scanderw TJ Wrangler Technical Forum 5 09-21-2009 12:44 PM
06 TJ speedometer calibration trav_k1234 TJ Wrangler Technical Forum 7 09-19-2009 03:56 PM
Speedometer Calibration...? drvnwheel JK Wrangler Technical Forum 4 06-03-2009 03:10 PM
Speedometer Calibration Bassbuster TJ Wrangler Technical Forum 5 08-19-2005 08:08 PM
speedometer calibration wrangler45 TJ Wrangler Technical Forum 10 06-23-2003 09:58 PM
