Quantcast speedo & tripometer/mileage not working after new clutch install, help please! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > speedo & tripometer/mileage not working after new clutch install, help please!
Old 10-25-2006, 07:55 PM   #1
NCJEEPFAN
98 TJ Sport
BB, Skyjacker Hydros, Teraflex Discos, Great Stereo
05 WK Laredo
4.7, 4wd......exhaust and gps coming soon!
NCJEEPFAN is offline   Reply With Quote
Old 10-25-2006, 07:56 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Either you removed the speedo gear housing and didn't rotate it to the right position after reinstalling it, or you broke one of the wires in the cable leading to the speedo gear housing. My bet is you don't have the housing index mark rotated far enough to engage the speedo gear with the pinion gear.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 10-25-2006, 08:40 PM   #3
bobbert350
yea u have not of done that right... check that thats the main thing
bobbert350 is offline   Reply With Quote
Old 10-25-2006, 09:02 PM   #4
NCJEEPFAN
so there should be a mark of some kind to line up?
98 TJ Sport
05 WK Laredo
Old 10-27-2006, 06:23 PM   #5
NCJEEPFAN
98 TJ Sport
05 WK Laredo
Old 10-27-2006, 06:29 PM   #6
mdm
Farm Wheeler
Take a look at step #9.
mdm is offline   Reply With Quote
Old 10-27-2006, 06:54 PM   #7
dyna
If its like the cherokee I had the clamp is similar to a distributor clamp and if you look closely at it there will be divits in the body where the clamp was. If pulled out you will see the gear is off set so as mentioned it has to be rotated to the correct spot.
dyna is offline   Reply With Quote
Old 10-29-2006, 03:51 PM   #8
NCJEEPFAN
thanks for the info, i got it fixed today. you guys rock!
98 TJ Sport
05 WK Laredo
Old 10-29-2006, 05:45 PM   #9
Jerry Bransford
So what was the fix?
Getting Savvy...
Old 10-30-2006, 08:48 PM   #10
NCJEEPFAN
sorry i should have mentioned how i fixed it. the speed sensor just needed to be rotated toward the notch toward the bottom of the transfer case , to match the correct size of gear (which was 36, stock i assume). works perfectly now! thanks again!
98 TJ Sport
05 WK Laredo
Glock Forum
