speedo question?? - JeepForum.com
post #1 of 8 Old 04-04-2012, 04:46 PM Thread Starter
jzman10
2009 JK Wrangler
speedo question??
I have a 01 TJ on 33's and need to change out my speedo gear. I know it should be 31 tooth gear but is it a long or short shaft? thanks
jzman10 is offline
post #2 of 8 Old 04-04-2012, 04:50 PM
DCUnger
O1 would be a short, from what I have read.
DCUnger is offline
post #3 of 8 Old 04-04-2012, 04:51 PM
JBTJ
Short shaft. Check out http://www.transmissioncenter.org/speedometer_gears_for_dodge_and_jeep.htm So you do have 3.73 gears?
JBTJ is offline
post #4 of 8 Old 04-04-2012, 05:07 PM Thread Starter
jzman10
2009 JK Wrangler
yes i do. looking to change out to 4.56 since i do have 33's and i can only get to about 50-55 on the highway..lol
jzman10 is offline
post #5 of 8 Old 04-04-2012, 05:10 PM
JBTJ
So 4.56 gears and 33' tires would be a 39 tooth gear. I have 3.73 gears and 32's and no problem doing 85+
JBTJ is offline
post #6 of 8 Old 04-04-2012, 05:18 PM
JBTJ
I see you have the 4 banger. I would regear to atleast 4.88 or maybe 5.13 for the 33's
JBTJ is offline
post #7 of 8 Old 04-04-2012, 07:35 PM Thread Starter
jzman10
2009 JK Wrangler
even if i dont plan to go with any bigger tires..it is a 4cyl auto..would that not run the rpm's to high??
jzman10 is offline
post #8 of 8 Old 04-05-2012, 05:24 AM
JBTJ
I know a few guys that have that combo, 4.88 and 33's and they like it.
JBTJ is offline
Speedometer question, I have proper axle gear, tire, Speedo gear but speedo still off crawlr TJ Wrangler Technical Forum 25 12-25-2011 07:15 PM
Speedo Question (not your average speedo queston though) EJames1226 YJ Wrangler Technical Forum 3 05-01-2008 09:51 PM
Speedo question ScotteeYJ YJ Wrangler Technical Forum 3 01-05-2007 02:57 PM
A Different speedo question zapp168 YJ Wrangler Technical Forum 11 11-30-2005 06:45 AM
Speedo Question JQlaxTJ TJ Wrangler Technical Forum 1 08-11-2005 08:04 PM
