spectre intake - JeepForum.com
post #1 of 2 Old 10-17-2010, 06:40 PM Thread Starter
nunyagdb1
spectre intake
I was wanting to put a cold air intake for my tj & i was pretty much set on a k&n until i saw the one from spectre. Unlike the regular kinds that pull air from under the hood, this one draws air in from the cab through a hole in the fire wall. The filter is in the tube & all this is suppose to keep it from sucking in water if you take it swimming. My problems with it are: would the air be any colder since the hole goes by the heater box, woulden't there be more noise to deal with & if it's so great then why is it only $160 when others start around $200. I'm just looking for some advice before I waste money on something that isn't worth it. Thanks
nunyagdb1 is offline
post #2 of 2 Old 10-17-2010, 06:50 PM
26679cj5
if you type "Spectre Intake" into the search box up top, theres a bunch of threads on this thing, even like 2 or 3 from the past week.
26679cj5 is offline
spectre cold air intake thel8one TJ Wrangler Technical Forum 204 01-13-2014 03:41 PM
Spectre cowling intake tjsean0308 TJ Wrangler Technical Forum 3 10-15-2010 08:07 PM
is this somthing new ? Spectre performance thickone TJ Wrangler Technical Forum 16 09-20-2010 08:56 AM
spectre performance intakes 06WranglerX TJ Wrangler Technical Forum 18 09-19-2010 01:59 PM
Installed 4.0L TB, 62mm Spacer, High Flow Intake, and bored out intake manifold... micfly83 YJ Wrangler Technical Forum 35 08-21-2006 05:32 PM
