Speakers - JeepForum.com
post #1 of 16 Old 11-09-2010, 07:46 PM Thread Starter
Zjones1994
Speakers
My front speakers are making a burning smell and my rear speakers arnt even working. There is an amp under the front seat (but from what i can tell there arnt any subs) and its not a factory radio. I bought the jeep and i hope to put new speakers in and i was hoping for advice on where to get moderetly priced speakers and how to hopefully remove the amp and find a factory radio
Zjones1994 is offline
post #2 of 16 Old 11-09-2010, 07:52 PM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
Walmart sells name brand inexpensive stereo equipment or try Crutchfield.com for everything.Remove the amp and stereo and get a high powered head unit(CD) and new speakers without an external amp.
TheBoogieman is offline
post #3 of 16 Old 11-09-2010, 08:04 PM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
People are pulling stock head units all the time for aftermarket ones.
Keep an eye on Craigslist or look in the forum classifieds.
Some will just send you their old unit for shipping costs only.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #4 of 16 Old 11-09-2010, 08:48 PM Thread Starter
Zjones1994
do i need special speakers for the front since their not circular? and do you know what size?
post #5 of 16 Old 11-09-2010, 09:00 PM
seadoons
They are an oval shape...you have to look behind the cover on the dash. I believe they are a fairly standard size...
seadoons is offline
post #6 of 16 Old 11-09-2010, 09:02 PM Thread Starter
Zjones1994
alright and to get to them does the grill just pull off or is there screws
post #7 of 16 Old 11-09-2010, 09:06 PM
seadoons
There are two screws on the "side" of the speaker cover - you should see them. They are pretty obvious. From there the cover pulls right off and you will see that old speaker sitting there. I am not sure what size they are - maybe 4x6? Or 3x5 (not sure if this is an actual size).
seadoons is offline
post #8 of 16 Old 11-09-2010, 09:10 PM
Fropleyqk
Fropleyqk's Avatar
The fronts are 4x6 but not standard size. Youll need to get an adapter bracket to mount them in. There's also adapters to mount 5 1/4s up there too. If youre looking to replace stock, Ill send you all 4 stock speakers for the cost of a 12 pack and shipping. Let me know!
Fropleyqk is offline
post #9 of 16 Old 11-09-2010, 09:22 PM
DustinS
2011 JK Wrangler
At Crutchfield.com, they give you adapter brackets if you buy 4" speakers for the dash. 4" isn't much, but you can hear the music without the sound bar in.
If I regret anything, it's not buying higher quality speakers. Probably will be upgrading to 5 1/4" in the dash in the future.
2011 Wrangler Rubicon, Zone 3" lift, 3/4" spacers, SRC Front and Rear bumpers, Bushwacker flares.
DustinS is offline
post #10 of 16 Old 11-09-2010, 09:25 PM Thread Starter
Zjones1994
alright and can i take out the amp and still have sound and hopefully get sound in the back and i just learned theres suposedly a sub under the center console
post #11 of 16 Old 11-09-2010, 09:40 PM
JeepnBlake
Don't be so quick to dismiss what good things you have going on. Many aftermarket headunits will pump out a decent jump in wattage over the stock HU. With that said there are a lot more people who want amps than those who don't.
The amp may be small enough for you to use to run your speakers. If its big enough, run a sub, even a single 6.5 or 8" sub will be a noticeable improvement.
As far as your speakers go, find some 5.25" speakers you like and get 2 pair, they pop right in the sound pods, and then check out the adapter rings people are making (or buying) over in the electrical forum.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #12 of 16 Old 11-09-2010, 10:09 PM Thread Starter
Zjones1994
well no such luck as a sub i just went and checked but any advice what to do about the rear
post #13 of 16 Old 11-09-2010, 10:45 PM
scs2016
X2 on Crutchfield, which has great selection and fitment guides (they'll send you free adapters for the dash speakers). I'm very happy with my folks from Crutchfield.
I found a factory stereo new on ebay for about $70 two-ish years ago. I think the model is called RBK. The only tough part of that install is getting the security bolt off the back of the old head unit -- which may not be an issue removing your aftermarket unit.
Good luck.
PS-I'd also ditch the amp. For a jeep, I think it would be too likely to be stolen or waterlogged...
If your jeep had a factory sub it would be in your center console (under the compartment).
04 TJ 4.0L, 5-sp, 2.5" OME lift with 1.25 BL
99 XJ, 2WD, 4L, AW4, 190K
scs2016 is offline
post #14 of 16 Old 11-09-2010, 10:49 PM Thread Starter
Zjones1994
alright so how do i ditch the sub? do i just remove it or what?
post #15 of 16 Old 11-09-2010, 11:08 PM
JeepnBlake
Your 98 likely won't have a factory sub in it, as with anything a picture is worth a thousand words, so if you can post a few up and we can give you more and better advice.
-Blake-
Build Thread:
Dad's Build Thread:
amplifier , audio , speakers
Speakers WranglerRush Wrangler General Discussion 4 11-13-2008 05:28 PM
What Speakers to replace stock speakers with? MSG_TweetyBird Wrangler General Discussion 17 07-21-2008 02:16 PM
Marine Speakers vs Auto Speakers Sakis94Wrangler YJ Wrangler Technical Forum 14 06-11-2008 10:24 PM
Speakers XJtheTanK YJ Wrangler Technical Forum 9 10-06-2006 12:10 AM
Speakers K2Racing YJ Wrangler Technical Forum 8 11-06-2004 12:35 AM
