which spark plug wires for 4.0? - JeepForum.com
post #1 of 12 Old 06-08-2004, 01:17 PM Thread Starter
greeneggsnham
i went to auto zone to replace my plug wires. selected the double silicone lifetime plug wires for twenty bucks. the guy turned out to be a jeeper with a 2k tj. he said that he replaced his plugs and wires with the az double silicon and it ran like crap so he changed wires to the az bosch wires that sell for thirty something bucks and "it made all the difference in the world". he said because of the odbe or something that the 4.0 had to have original equipment wires or good wires like the bosch. my stealership wants forty one dollars for the stock wires. i'm wondering what the heck? any thoughts or suggestions? i'm running a 98TJ with a 4.0 and champion truck plugs.
DO NOT BUY FROM Rocky Road Outfitters. Just ask me why...
greeneggsnham is offline
post #2 of 12 Old 06-08-2004, 01:26 PM
holyundrwr
holyundrwr's Avatar
not sure about the wires, but thru others and own experience, champion plugs do fire a heck of a lot better than some more expensive ones
'97 TJ Sahara 4" PRO COMP EXPLORER SUS LIFT
4.10'S D30/44 LOCKED 34 X 10.50 SUPER SWAMPERS
AIRAID INTAKE/ TB HELIX SPACER GIBSON HEADERS
LOTS MORE GOODIES, LOTS MORE TO COME!
BARBERPOLE DRIVESHAFT JEEP CLUB #1
holyundrwr is offline
post #3 of 12 Old 06-08-2004, 05:07 PM Thread Starter
greeneggsnham
i am running the champion truck plugs.... and i like them. wondering about the wires?????
post #4 of 12 Old 06-08-2004, 06:02 PM
doorocks
doorocks's Avatar
GEH....................CLEAN OUT YOUR PM BOX!
Steve
LIFE IS TOUGH ENOUGH ALREADY, IT'S EVEN TOUGHER WHEN YOU'RE STUPID.
RE 3.5 and all kinds of other relevant goodies, you know winch and stuff.
Life is like walking into the No Chance Bar full of Future Darwin Stories........
More mods than a hillbilly's set of teeth..
doorocks is offline
post #5 of 12 Old 06-08-2004, 08:14 PM
cwbyup
Newbie question
I'm a rookie when it comes to spark plugs, so...sorry. How do you go about changing them and where are they (i think I know where but i'm not positive)? Do i just take them out and put new ones out?
1998 Black Wrangler Sport
John Deere Floormats
Set of 30 x 9 Dunlop Mud Rovers
4 Eagle One Off Road Lamps
CB
4' Wilson Antenna
-had not Firesticks in Stock:(
Sirius Sattelite Radio
Saving up for more toys
cwbyup is offline
post #6 of 12 Old 06-08-2004, 08:20 PM
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
2013 MJ Comanche
yup, just follow the (six?) large wires that go to the passenger side of the engine, evenly spaced apart and come from the distributor cap (a single spot), where they meet the engine is the spark plugs. You should be able to pull them off and see the top of the plugs. Any autozone employee would be more than willing to give you a 5 minute crash course and show you what you need. If you feel like he's trying to sell you a load of crap. Thank him for his time and leave. Usually those guys are alot of help, and don't work on commission, so they don't care what you buy. You probably know someone who knows something about cars, ask around...
Hope this helps,
Lone Jeeper.
ಠ_ಠ
LoneJeeper is offline
post #7 of 12 Old 06-08-2004, 09:36 PM Thread Starter
greeneggsnham
you will need an extension for the number one wire as it is behind the alternator. use a pair of pliers and gently pull the boot off the wire. it's easy if you have a long handled pair of pliers.
post #8 of 12 Old 06-09-2004, 04:20 AM
fyrfyter43
fyrfyter43's Avatar
That tells me that the guy at AZ is full of ****!!! My 2k 4.0 doesn't even have wires! It has the coil rail set-up. I could be wrong, but I'm sure that all 2k's would have the coil rail set-up.
fyrfyter43 is offline
post #9 of 12 Old 06-09-2004, 04:42 AM
TJinWV
TJinWV's Avatar
Just a quick note of help for the rook - take them off and replace them one at a time! If you take them all off together, you'll forget which plug goes where on the dist, and you'll have to log on to JeepForum and ask someone.
How do I know this?
Dan - TJinWV <>< |
2002 TJ, 2" OME lift, ARBs
TJinWV is offline
post #10 of 12 Old 06-09-2004, 07:34 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
OE plug wires are hard to beat. Most other plug wires are junk, even the so-called premium wires. NONE of them will make your engine run any better than the OE wires do, that is for sure. Avoid at all costs those "low resistance" wires since they'll only make more ignition noise that your radio will pick up.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #11 of 12 Old 06-09-2004, 10:15 AM
mattyxxl
mattyxxl's Avatar
That is exactly what i was thinking.... you beat me to it!
All the 4.0 2k and on have the coil rail....
I hate AZ.... horrible store.
But then again i work for the competition! AAP
2000 TJ Sport
4.0 Auto
Solar Yellow, Soft Top
Yellow Jeep Club Member #88
mattyxxl is offline
post #12 of 12 Old 06-12-2004, 01:14 PM Thread Starter
greeneggsnham
i went with ac delco wires. seems to be running fine and steady.
Spark Plug Wires sealion2288 TJ Wrangler Technical Forum 5 03-23-2009 06:20 PM
2.4L spark plug wires Mais das me! TJ Wrangler Technical Forum 9 08-14-2007 06:58 PM
7mm or 8mm spark plug wires? BoHeck TJ Wrangler Technical Forum 1 05-26-2007 11:52 AM
Spark plug wires Jayeep YJ Wrangler Technical Forum 5 11-04-2005 07:59 PM
Spark Plug Wires fsas311 TJ Wrangler Technical Forum 2 09-12-2005 06:41 PM
