Spark Plug & Oil Drain Plug Torque Specs - JeepForum.com
post #1 of 8 Old 08-28-2009, 05:19 PM Thread Starter
bfewkwa
Guys,
Been searching and can't find the oil drain plug torque specs for my 04 Rubicon.
I didn't get a manual with my TJ and it's due an oil change.
Also got a new set of plugs to go in. Is there a torque spec for the plugs?
Anyone have the specs handy?
bfewkwa is offline
post #2 of 8 Old 08-28-2009, 05:25 PM
happymudder10
Spark plugs are 22ftlb and the coil rail screws are 21ftlbs. I seem to recall reading somewhere that the oil drain plug is 27 ftlbs.
Personally, I have never "torqued to spec" any of these. I just use common sense.
Just a traveling cat in a tall black hat riding a goat. Nothing to see here.
happymudder10 is offline
post #3 of 8 Old 08-28-2009, 05:26 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
spark plugs are 2 grunts past snug.
oil drain plug is tight - maybe 1/2 grunt past snug.
If you really care that much: http://www.jeepforum.com/forum/f9/tj...-specs-474605/
Good luck getting a torque wrench in for the spark plugs, heck you can barely get a ratchet and a 6" extension in the #6 cylinder.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 8 Old 08-28-2009, 06:16 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
You will get use to not using a torque wrench for a plug change.
GOLENJEEPTJ is offline
post #5 of 8 Old 08-28-2009, 06:31 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Stick with nothing larger than a 3/8" drive ratchet wrench and you won't have to worry about over-tightening them. With a 3/8" drive, I tighten them both to no more than one grunt. Using a 1/2" drive is just asking to overtighten/strip those sizes of parts out.
Jerry Bransford is offline
post #6 of 8 Old 08-28-2009, 07:05 PM Thread Starter
bfewkwa
Thanks. I guess I should have clarified that I have a history of stripping threads. I thought I would start out right on the Jeep and use a torque wrench from the start. Plus, good excuse to buy a better torque wrench.
bfewkwa is offline
post #7 of 8 Old 08-28-2009, 07:19 PM
nmj48
from the 04 FSM for the 4.0L engine
oil drain plug 25 FT/LBS
coil rail 250 IN/LBS (21 FT/LBS)
sparkplug 27 FT/LBS
nmj48 is offline
post #8 of 8 Old 08-28-2009, 07:19 PM
tangofox007
That's a smart move. It's hard to go wrong doing things the right way.
tangofox007 is offline
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 04:26 AM
large drain plug and fill plug stu'sjeep TJ Wrangler Technical Forum 4 04-21-2008 09:14 PM
Drain Plug Torque 06bigdaveJP TJ Wrangler Technical Forum 11 04-13-2007 06:19 PM
Spark Plug Rail Torque? fundabug TJ Wrangler Technical Forum 6 04-09-2006 06:52 PM
Spark plug torque rjcobra TJ Wrangler Technical Forum 3 03-13-2006 06:56 PM
