Spark plug crush washer direction - JeepForum.com
post #1 of 6 Old 05-06-2011, 07:08 PM Thread Starter
keithert
keithert's Avatar
I got a set of Autolite APP985 that came with crush washers. One side is flat and one is tapered. Which side goes toward the plug screw base? The NGK's that came out just have a flat washer so they are no help.
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #2 of 6 Old 05-06-2011, 07:10 PM
ZJ5point2GCL
i am pretty sure the tapered seat goes towards the cylinder head.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #3 of 6 Old 05-06-2011, 08:38 PM
BlueFlame
BlueFlame's Avatar
Doesn't make one bit of difference.
BlueFlame is offline
post #4 of 6 Old 05-06-2011, 08:40 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
X2^,just put the plugs in and tighten.
GOLENJEEPTJ is offline
post #5 of 6 Old 05-06-2011, 08:52 PM
chris142
I've wondered if the washer went a certain way or not. Never seen any instructions on it. I always put the wider part of the washer against the head.
chris142 is offline
post #6 of 6 Old 05-06-2011, 09:15 PM
AntiPrius
I always put the narrower part towards the engine block, although it doesn't matter...I still always do it.
AntiPrius is offline
windshield washer plug gashead JK Wrangler Technical Forum 6 02-02-2011 07:20 PM
Bushing washer, crush sleeve, and cutting floor pan Que89YJ YJ Wrangler Technical Forum 3 01-29-2011 08:29 PM
Spark plug crush washer rdhclark TJ Wrangler Technical Forum 4 11-27-2009 01:10 PM
Spark Plug & Oil Drain Plug Torque Specs bfewkwa TJ Wrangler Technical Forum 7 08-28-2009 06:19 PM
Spark plug gap Nosh686 YJ Wrangler Technical Forum 4 12-30-2005 03:23 AM
