Spare tire on tailgate: Reinforcement brackets? - JeepForum.com
post #1 of 9 Old 07-07-2010, 10:38 PM Thread Starter
armyRN
armyRN's Avatar
OR-FAB and TNT Customs sell spare tire carriers that mount to the tub. They have reinforcement brackets for the tub to help support the weight and stress of the new spare tire carrier. My 33" spare tire carrier is mounted to the tailgate. So my question is: Does anyone sell reinforcement brackets to mount behind/inside the tub and (maybe on the backside of the tailgate too) to reinforce the hinge/tailgate when you've got a larger spare mounted on the tailgate? Anybody ever tried this?
armyRN is online now
post #2 of 9 Old 07-07-2010, 11:30 PM
ElementX
The aftermarket tire carriers that bolt to the tub are a big improvement over the stock tire carrier, but still suffer from issues with getting caught up on ledges. For the most part, they bypass the weak points in the stock setup.
1) tailgate hinges - where to find decent looking hinges that would still allow safe functionality of the tailgate?
2) tailgate door striker - the list of door striker upgrade threads are zip
3) stock tire carrier - if you can build a stronger one, you may as well build the bumper and swing out to go with it
'98 TJ Sport
ElementX is offline
post #3 of 9 Old 07-07-2010, 11:51 PM
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
been running my 33" spare tire on the stock tire carrier for at least 3, if not 4 years...it's still hanging there, and the tailgate works just as good as new. Make sure that the spare is snug against the rubber snubbers (or bumpers, or what ever you may want to call them).
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
post #4 of 9 Old 07-08-2010, 01:15 PM
Fargo
I too have been hoping to see something to simply reinforce the existing tailgate to be able to run a taller tire on it. I believe that someone makes one for the JK but not the TJ. What is it that usually causes the problem. Is it the hinges bending or the tailgate warping?
6spd manual
LJ Owners Group member #110
Fargo is offline
post #5 of 9 Old 07-08-2010, 01:50 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I've been running 35's on the stock carriers for years with no problems.Get the weight off the carrier and onto the bumper some.Adjust the bumpstops on the tailgate too.Easily welded bracket.
TheBoogieman is offline
post #6 of 9 Old 07-08-2010, 08:47 PM
PhulesAu
I like and use the bestop carrier. Used hockey pucks are your freind..
PhulesAu is offline
post #7 of 9 Old 07-09-2010, 02:52 AM Thread Starter
armyRN
armyRN's Avatar
Thanks for the responses. I guess I'll have to try and fabricate something and see what I can come up with.
post #8 of 9 Old 07-09-2010, 01:38 PM
john NC
john NC's Avatar
1979 CJ5
i've had a 33 on mine for a couple of years no problem, i just relocated the 3rd brakelight to the center of the spare and made sure it was nice and snug against the rubber bumpers
i do put it in the back when i take it offroad though
john NC is offline
post #9 of 9 Old 07-09-2010, 05:43 PM
BestopTeam
Vendor
BestopTeam's Avatar
2010 JK Wrangler
That's basically what the Bestop tire carrier for the TJ is. The advantage is it allows the tire to swing w/ the tailgate.
If you fabricate something yourself, keep in mind that it's not so much the weight that's an issue, it's the cavitation - the back and forth bending. Sort of like how you can stand on an empty beer can, but if you bend the sides even a tiny bit, it won't hold any weight at all.
It's why you need to make sure your tire on the stock carrier isn't vibrating at all. Like PhulesAu, says, hockey pucks or spacers or whatever, to keep the tire still.
BestopTeam is offline
spare , tire , tailgate
35" spare tire adapter and carrier reinforcement ZBoater JK Wrangler Technical Forum 11 06-14-2010 05:56 AM
Tailgate reinforcement question for 35" spare JackBauer JK Wrangler Technical Forum 26 03-02-2010 09:15 PM
Tailgate Rack for '05 TJ (Over the spare tire) tjmas TJ Wrangler Technical Forum 0 10-16-2009 12:52 PM
Tailgate welds? Tailgate reinforcement? Xtremjeepn JK Wrangler Technical Forum 19 07-10-2009 09:40 PM
Spare Tire/Tailgate Rack TedderX_ TJ Wrangler Technical Forum 12 02-15-2009 08:56 AM
