Spare Tire Size; Axle Damage If Unequeal ? - JeepForum.com
post #1 of 19 Old 05-23-2010, 04:01 AM Thread Starter
06choppertj
Is it rumor or fact ? On a jeep, if you put a spare on that is smaller, bigger, than the other 3 tires, will you damage the diff. ? For example, the doughnut spares that are on all newer vehicles are the norm. They seem to function well with no adverse affects. What say `Ye ?
06choppertj is offline
post #2 of 19 Old 05-23-2010, 04:06 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
do you have a locker?
I've run a smaller spare before and didn't have a problem.
Also, I've heard problems of off sized tires causing problems. One story was that the R&P kept having troubles because of the front 2 tires being 1/2" difference in size.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #3 of 19 Old 05-23-2010, 04:34 AM
RogueSpear2023
As long as you don't have a locker or a limited slip it shouldn't be a problem. If you do have a locker or LSD then the tires must be the same size.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #4 of 19 Old 05-23-2010, 07:47 AM
djt283
djt283's Avatar
As long as your axles are stock and no limited slip in the rear, you'll be fine. Proof of that is new jeep models with solid rear axles come with undersized spare tires on the low-end models.
djt283 is offline
post #5 of 19 Old 05-23-2010, 07:52 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
That is only on all wheel drive jeeps, or like stated above those with lockers. If you run it in 4wd with a smaller spare it can cause problems, but in 2wd on open diff's the odd sized tire will do no harm.
xjfever is offline
post #6 of 19 Old 05-23-2010, 11:15 AM
Neil F.
If you have a LSD, you are not going to distroy it. A LSD is slipping all the time in normal conditions (cars with donuts have LSDs also) A smaller spare will cause constant slip but it's not going to make it expload or wear it out quickly.
Neil F. is offline
post #7 of 19 Old 05-23-2010, 11:47 AM
van1
Using a smaller spare...
W/locking diff. Dont do it unless it is your last resort...as it would be hard on the components and driving as it would act like you were constantly turning, drive slow...
W/LSD Don't do it unless it is almost your last resort(I wouldnt do it) unless it was the last resort. On a LSD with clutches it would cause wear and is hard on it...still drive slow but would be easier than a locked diff
W/open I would do it, but don't do it for long periods as it makes the diff work harder and causes wear as it would be constantly working the spider gears.
I might end up running a smaller spare, but I wouldnt run it long. Just for me to get somewhere to get the org. tire fixed. This is much better than no spare....
van1 is offline
post #8 of 19 Old 05-23-2010, 04:52 PM Thread Starter
06choppertj
Thanks everyone for your responses. I appreciate it. You have helped me make a good decision on tire set ups.
post #9 of 19 Old 05-23-2010, 08:05 PM
djt283
djt283's Avatar
What happens then when my open diff goes around turns? If I make a bunch of rights in a row will my gears shatter?
djt283 is offline
post #10 of 19 Old 05-23-2010, 08:18 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
With a selectable locker unlocked, no problem...
Knuckelhead is offline
post #11 of 19 Old 05-23-2010, 09:26 PM
J03_TJ
I know I wouldn't do it with my rear Truetrac and front Aussie. I know the front would handle it for a while as long as not in 4x4, but the rear would also get a workout I would think.
J03_TJ is offline
post #12 of 19 Old 05-23-2010, 10:52 PM
Demp
Having tires of drastically different sizes on an open differential only cause uneven tire wear on the other tire and maybe a little pull from the weight being off balanced from the lean. As others said the LSD/lockers won't like it either.
Short term don't worry about it, long term....... there shouldn't be a long term.
Demp is offline
post #13 of 19 Old 05-24-2010, 07:30 AM
chadsmeltzer
chadsmeltzer's Avatar
Do you drive in circles for 100+ miles? It won't be a problem with different sized tires for short distances, but don't just leave it for weeks/months.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #14 of 19 Old 05-24-2010, 08:37 AM
perrymn
great question! Thanks
99 TJ Sahara.
perrymn is offline
post #15 of 19 Old 05-24-2010, 08:48 AM
wlmonk
My two cents: If you are putting a spare on a LSD, the spare doesn't need to be the same SIZE as the other three tires, but it should be the same DIAMETER.
Just wanted to clear that little matter up.
wlmonk is offline
limited slip , locker , spare , tire
need help asap (Does running different size spare cause axle damage) SwissK31 TJ Wrangler Technical Forum 6 03-11-2010 06:05 PM
Spare Tire Fit Backspacing/Tire Size? Stingray427 JK Wrangler Technical Forum 2 02-04-2010 11:30 PM
max tire size for a stock spare tire mount?? G-MANtj TJ Wrangler Technical Forum 31 05-14-2009 09:36 PM
What size tire can the spare tire holder handle Tarheelkidd YJ Wrangler Technical Forum 26 09-26-2005 01:51 PM
What is the biggest size tire the factory spare tire holder will hold? keys741 TJ Wrangler Technical Forum 13 08-03-2003 01:59 PM
