spare tire lock. how to remove without key! - JeepForum.com
post #1 of 5 Old 01-20-2003, 09:11 PM Thread Starter
eastwood
here is my problem, by the way, this is my first post so bare with me. the key lock for my spare tire is stripped out. is there a universal key i can get some where? i took it to the jeep dealer and they told me they could cut it off, but it would cost me $100! has anyone been in this situation? and of so, what did you do?
eastwood is offline
post #2 of 5 Old 01-20-2003, 09:17 PM
igofshn
Locked @ both ends
igofshn's Avatar
Go to a tire shop. They can get it off for you, or you can pound a socket onto the lock and use that. You probably won't be able to use the socke again. Also you could try a cut off wheell.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 5 Old 01-20-2003, 09:22 PM
fashionbiff
Sometimes you can get lucky, losen the other two nuts and then try and loosen the lock with a pair of vise grips. To increase your chances you could grind two flats on opp. sides and try the vise grips or crescent with a cheater bar.
But any good tire place should be able to do it for a resonable fee.
fashionbiff is offline
post #4 of 5 Old 01-20-2003, 09:40 PM
macb
macb's Avatar
I had this problem when I got my jeep, a cheap 12 point socket that was hammered on with a BFH and it came right off - notice -
cheap socket...you probably won't be able to get it off after.
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah:
Bob Supplee:
or (405) 799-8977
Stu Olson's great jeep resource site:
macb is offline
post #5 of 5 Old 01-21-2003, 12:44 PM
asjeep
or get a angle grinder, and grind away a slice of it.... then you can use any crowbar and turn it right off.... used to work in a tire shop that was one way we would do it
A tire shop BTW will charge about 10.00 to do it... try discount tire or sears.....
2002 TJ SE
asjeep is offline
Can I remove spare tire without tpms going off? moosey41 JK Wrangler Technical Forum 10 06-27-2009 12:14 PM
Does anyone LOCK their spare tire? PatrickBateman JK Wrangler Technical Forum 15 02-13-2007 01:23 PM
How to remove spare tire carrier from tailgate Erik T. TJ Wrangler Technical Forum 16 09-11-2006 03:46 AM
I want to remove my spare tire carrier can i remove it and reuse the brake light? Capinsano3 TJ Wrangler Technical Forum 4 09-05-2006 09:03 AM
Spare tire lock. Hoe to remove without using key!? eastwood YJ Wrangler Technical Forum 13 01-21-2003 06:34 PM
