Spare different size - JeepForum.com
post #1 of 44 Old 06-06-2007, 11:29 AM Thread Starter
Morgen251
2010 JK Wrangler
Anyone know where (or have one) I can get a single Maxxis Bighorn 31x10.5?
The guy I bought my jeep from only had the four mounted, the spare is a Goodyear Wrangler 215 75R15.....I'm assuming it wouldn't ride right if needed as a spare.
Willing to trade as well.....
2010 JK Wrangler. Born to me on 12/28/09 when El Jeepo (TJ) decided 160K was enough, and threw a rod through a cylinder.
BUILD:
Rubi Rocker Guards; 32" Mastercraft MTs; Teraflex 2.5" Coil Spring Lift; JKS Quick Discos; JKS Front & Rear Adj Trackbars; JKS Ex Rear Swaybar links; Zone Nitro Shocks; 1.5" Rough Country Wheel Spacers; Poison Spyder Evap Skid; Cobra 75WXST; 3' Firestick quick disco; Rugged Ridge XHD Fr Bumper; Tuffy Underseat Drawer; 6" KC Long Range Hilites; Superchips Flashpaq, Crown Extended brake lines
WISH LIST: Front LCAs, Winch, 6" KC Driving Lights, Deep Cycle Battery
Morgen251 is offline
post #2 of 44 Old 06-06-2007, 11:56 AM
Combatsylvania
a short distance on a undersized spare isnt horrble... just dont put in in 4 wheel drive
2006 TJ SE - Does what I want it to do.
Combatsylvania is offline
post #3 of 44 Old 06-06-2007, 12:07 PM Thread Starter
Morgen251
2010 JK Wrangler
Just wanted to make sure it wouldn't be a compatability issue and cause major problems. I'd only use until I could get somewhere to get the main fixed.
Thanks Combatsylvania....always droppin the good knowledge.
BUILD:
post #4 of 44 Old 06-06-2007, 12:12 PM
KennyTJ
Never ever use a tire of a different size front or rear. Turning your Jeep into a tripod will cause handling problems that can kill you and someone esle on the road!
A 215/75 15 is only a 28" tire, that 3" sorter!
Seriously you can find all kinds of tires locally and on forums for less than $50 for a good spare, please find a spare that is at least the same dia.
THINK OF THE CHILDREN MAN!~
Silver '06 TJ w/ neat stuff on her!
"New" 1987 YJ Project for my son!
KennyTJ is offline
post #5 of 44 Old 06-06-2007, 12:14 PM Thread Starter
Morgen251
2010 JK Wrangler
That was my first thought (not of the children, of the compatability and size difference). Maybe I can find someone who wants a trade.
Standard tire carrier on the TJ strong enough to hold a 31 without hinge damage?
BUILD:
post #6 of 44 Old 06-06-2007, 12:20 PM
TJinWV
TJinWV's Avatar
Lots of folks run 31s on the stock carrier without issues. I noticed mine was getting a little hard to swing after a couple of years, so I got the bestop carrier.
Dan - TJinWV <>< |
2002 TJ, 2" OME lift, ARBs
TJinWV is offline
post #7 of 44 Old 06-06-2007, 12:22 PM Thread Starter
Morgen251
2010 JK Wrangler
Sweet....hoping to not have to buy a new carrier right away. Still waiting for my new top to come in....
BUILD:
post #8 of 44 Old 06-06-2007, 12:43 PM
Rubi22
Rubi22's Avatar
He's right, concerning the dangers. Otherwise, if you feel confident and it's only a short trip from the trail to your garage, it's fine as long as you don't have a locker/limited slip. It just means it'll be spinning faster than the others.. overuse of this (i assume) would cause abnormal tire wear, but for a minor ride, i don't think there'd be a problem.
But again, don't drive home confident that it'll handle like normal.
Rubi22 is offline
post #9 of 44 Old 06-06-2007, 12:45 PM Thread Starter
Morgen251
2010 JK Wrangler
I think I'm just going to try to swap this one out for a spare 31 to remove all doubt. Thanks for the tips!
BUILD:
post #10 of 44 Old 06-06-2007, 12:51 PM
Combatsylvania
it handles like any car does on a donut..
I recently found a set of super cheap matching tires (bald) that im gonna buy so I have a full sized spare... but to get you home a smaller spare is fine.
Your only talking about a 1.5" radius difference... now if it was a set 35 inch tires with a 28" spare i wouldn't dream of using it.
post #11 of 44 Old 06-06-2007, 08:45 PM
JEEP97TJ
How have those maxxis bighorns performed--street/trail. I am looking at some 31x10.5 or 32x11.5 bighorns? good luck with your spare
Blacksburg, VA
JEEP97TJ is offline
post #12 of 44 Old 06-06-2007, 08:53 PM
Rubi22
Rubi22's Avatar
good point...
Rubi22 is offline
post #13 of 44 Old 06-07-2007, 07:16 AM
PeteC
Exactly.
There will be no problem getting off the road with a smaller spare. Treat it like a donut and you will be fine. Slow speeds.
Used a smaller (30 when I was running 33) tire on the back of my TJ once to get somewhere to get it fixed. I have the TracLoc LSD in the back but had no problems with handling. I just drove speed limits to town from the campground.
I have heard it could be a problem with a lunch box locker though. Difference in wheel spin would cause the locker to engage. I could see this being an issue in the front especially.
Seems that I have heard many times that a tire within one size would work, even in these circumstances.
On the trail though, you should have a spare as close in size as you can. Afterall, any difference onthe road will be multiplied offroad when off camber or climbing.
I carry a spare from my old set of tires. 33x9.5 BFG AT. My present tires are 33x12.5 TrXus MT's. When I increase my tires to 35 or 36" I will be buying 5 unless I find a great deal on 4. In which case I would be looking for a used 35 or 36 with even minimum tread left. Just enough to get me off the trail and get me home.
'00 TJ With toys, lift and tires.
'10 Dodge Ram 1500 Quad 4x4. Daily driver and tow rig
'05 Dodge Neon. Wifes daily driver and gas sipper.
There is no Bandaid for Stupidity
Sorry if my support of legal wheeling offends you
PeteC is offline
post #14 of 44 Old 06-07-2007, 07:47 AM Thread Starter
Morgen251
2010 JK Wrangler
My bighorns are great......so I'm looking for a 5th spare if anyone has one/knows of where to get one for a good deal.
So I'll treat it like a donut until I get me a spare. Makes sense to me..and I've got no lockers so I should be good to go there.
BUILD:
post #15 of 44 Old 06-07-2007, 08:38 AM
NYresq
if the flat was in the rear I would take the time to swap one of the front tires to the rear and put the smaller tire on the non driving axel to save the diff. even a factory posi rear will eat itself in a short period of time with a smaller tire size on the same drive axel.
NYresq is offline
What size of spare do I need to use? OzarkOutdoors TJ Wrangler Technical Forum 24 03-15-2010 08:36 PM
Spare Rim size denalione YJ Wrangler Technical Forum 1 04-18-2009 02:30 PM
What size spare? rdhclark TJ Wrangler Technical Forum 5 11-21-2008 10:47 PM
off size spare? monkeychrist TJ Wrangler Technical Forum 7 07-15-2007 04:21 PM
Spare Size ?? blevinsbulldog YJ Wrangler Technical Forum 8 02-04-2006 10:46 AM
