Spacers, good or bad? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Spacers, good or bad?
Rough Country Jeep Suspension Deals at Rockridge 4WD!Amsteel Blue Synthetic Winch line Free ShippingWarn and Smittybilt Free Shipping Offer
Unread 03-09-2003, 01:07 AM   #1
Mark TJ-YJ
Hi guys/gals.
I have a 3" Teraflex lift with Rancho RS9000 shocks on my 97 TJ. Before going on the Rubicon in July, I'd like to add a little more lift.
I found the cheapest way is to get a Daystar kit off Ebay;
http://cgi.ebay.com/ws/eBayISAPI.dll...category=33585
It's a 1 3/4" kit and I have some newbie questions
Will I need to get longer shocks or brake lines?
What common problem arise from doing this?
Will my driveshaft angle change, if so, how do I fix that?
Thanks in advance.
Mark
97 Jeep Wrangler TJ, 3" Teraflex lift, 33" BFG muds, Rancho RS5000X Shocks, ARB locker in the front, 4.56 gears,XRC front and rear bumpers, XRC 8000 winch, KozOffRoad Cage.
Mark TJ-YJ is offline   Reply With Quote
Unread 03-09-2003, 01:42 AM   #2
cptn_mrgn78
Your drive angle will change and the cheapest way to correct that is to drop your T-case although that is not the best way. You can correct the drive angle with a BL and MML and/or adjustable control arms, and SYE and CV. You may be able to get away with the shocks you have now but the safe bet is to get longer shocks. You might want to get a 1in BL and MML lift. It will give extra clearance and solve minor vibration problems although it will cost more than spacers.
RIP: '97 TJ with 2in Teraflex with QD's. 32in AT's. Hi-lift jack, two 10in subs and a 500 watt amp. 150watt KC Daylighters. Avalanche Engineering Rocker Knockers.
New: '05 Unlimited
cptn_mrgn78 is offline   Reply With Quote
