spacers - JeepForum.com
post #1 of 6 Old 07-28-2010, 11:14 PM Thread Starter
cam36
spacers
im not sure if this a dumb question but here it goes anyway, i plan on getting a lift kit down the road with shocks and springs and all that but right now i want something quick and inexpensive so im looking into a spacer, can i do spacers and a new lift kit with shocks and new coils? or would i have to take the spacer out
2012 Jk Sport S 6 speed
4.56s Detroit Trutrac rear
37x12.50 Nitto Trail Grapplers
3inch BDS w/ bilstein 5100s
cam36 is offline
post #2 of 6 Old 07-28-2010, 11:23 PM
06_LJCON
You can keep the spacers. Some people use them in combination with lift coils.
(SOLD) 1991 wrangler 2.5L 5-Speed White, 2" BL, Warn rear bumper, warn winch, warn rock sliders.
(SOLD) 1987 wrangler 2.5L 5-speed BLACK!
S.O.A. with 4" springs and a 2" body lift. Lincon locked front. 33" TSL's NEED bigger tires!!
(WRECKED) 2002 Apex Wrangler 4.0L 5-Speed Silver
2.5" skyjacker single flex, skyjacker shicks, Rock Krawler adjustable lower control arms f/r, 1.25" JKS body lift, 1" JKS motor mount lift, JKS Quicker Disconnects, Warn engine/transmission skid plate, Rock Crusher Front diff cover, Poison spyder rocker knockers, 1.25 wheel spacers, 4.10 gears f/r, Detroit Trutrack rear, aussie automatic locker front
(CURRENT) 2006 Wrangler Rubicon Unlimited LJ 4.0L 6-speep, Silver, 3.5" Rubicon express lift with Rubicon express disconnects. Hella 500 lights, HID Bi-xenon headlights, Rock-It intake, Red top Optima, Factory MOPAR rocker knockers, TNTCustoms Front full tube fenders, 35x12.5R15 BFG KM2, Black steel wheels.
06_LJCON is offline
post #3 of 6 Old 07-28-2010, 11:24 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The parts that come with lift kits are designed to work together for whatever lift height it is.
The shocks are a specific length so they provide a balance of uptravel and downtravel, or at least they are supposed to be.
The nicer kits include some adjustable parts that can accomodate different lift heights.
Generally speaking, its not a good idea to add spacers on top of a lift kit, but a little more info would be needed to give you a better answer.
What size coil spacer are you considering?
What lift are you considering at a later point?
Wheelin98TJ is offline
post #4 of 6 Old 07-28-2010, 11:24 PM
SugarBear
1969 CJ5
Yeah, I know people that have a 2.5" coil lift, and a 2" spacer lift (budget boost) for example.
You can do both.
1969 CJ5
2.5" Rancho Kit/Shocks/Steering Stabilizer, 2" Shackles, Koenig PTO Winch, 31x10.5x15 Cooper STT's
SugarBear is offline
post #5 of 6 Old 07-28-2010, 11:54 PM Thread Starter
cam36
I'm thinking 1 3/4 spacer and an RC 2.5 inch coil and shock lift
cam36 is offline
post #6 of 6 Old 07-29-2010, 12:13 AM
Wheelin98TJ
JEEP FREAK
You would be better off doing one or the other.
With the RC 2.5" kit, the only thing you would be using is the coils. Unless you could convince the seller to provide you with shocks that are for 4.25" of lift.
At 4.25" of lift, you will also have to address:
Track bars
Front brake hoses (if you will be disconnecting your sway bar when off road)
Driveline angles
Sway bar links
Coils are not the expensive part when it comes to doing a lift. It does not save you money to use coil spacers + shorter lift coils than it does to use longer lift coils.
spacers , coil , lift , lift + spacers
1.25 or 1.50 spacers jpg0511 JK Wrangler Technical Forum 1 11-27-2009 08:12 PM
Will I need spacers? JIME TJ Wrangler Technical Forum 2 04-20-2009 09:30 PM
11" wide tires; spacers or no spacers? Hilldweller JK Wrangler Technical Forum 19 07-01-2008 06:38 AM
Are spacers bad for the car??? schung39 TJ Wrangler Technical Forum 35 08-10-2007 02:45 AM
mml spacers mookarma TJ Wrangler Technical Forum 1 02-28-2005 04:23 PM
