Spacer Vs Suspension Lifts - JeepForum.com
post #1 of 7 Old 02-12-2007, 06:15 PM Thread Starter
cavinman
What is the advantage of the two lifts besides the price.
New to the jeep family
cavinman is offline
post #2 of 7 Old 02-12-2007, 06:17 PM
Rocky529
Rocky529's Avatar
With just 2" of lift, definitely go with the spacer route. A lot more cheaper.
Anything more than 2", and you will want to go the new coil route.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 7 Old 02-12-2007, 06:18 PM
McLovin
I can only think of one advatage the coil springs would have. That would be a higher spring rate. Which if you add heavy bumpers and what not will help prevent spring sag. I think generally if you are only going for 2" of lift most people go with spacers.
McLovin is offline
post #4 of 7 Old 02-12-2007, 06:20 PM
SecondTJ
SecondTJ's Avatar
You'll get more flex with a new coil, but other than that.
The biggest difference is price.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #5 of 7 Old 02-12-2007, 06:22 PM
Rocky529
Rocky529's Avatar
If you get a coil equal to exactly how much the stock coil and a suspension spacer equals, how would it be more flex?
Rocky529 is offline
post #6 of 7 Old 02-12-2007, 09:39 PM
beryl
coils handle better with less nosedive. plus the rear coil can dig into the spacer.
^ that is a quote from someone who has had a coil lift and then swapped it for a spacer lift and then he realized how much better the coil was. i think it was rusty the scoob or stu olson? also the second statement was a quote also from someone running a spacer in the rear...it may have been davenjeep...can't remember...posted a while back on another forum.
beryl is offline
post #7 of 7 Old 02-13-2007, 09:05 AM
99TJMark
Because springs compress and expand, spacers don't... I used to ask the same question...
It's a lot easier to fully compress (over-compress) a stock coil with a spacer lift, you'll have pretty much sagged the stock spring if you do that a few times, it's why you extend the stock bumpstops (less flex).
A full coil has a little more rate and slightly wider spacing on the turns and also a slightly longer wire to it. It is more forgiving because you'll hit the stock bumpstop before you fully compress it. Hence more flex.
This is the way it was explained to me by a spring shop, made the most sense to me and is why I got a 2" full coil spring kit.
99TJMark is offline
What is the best.... (suspension lifts and body lifts) RjAndJeep TJ Wrangler Technical Forum 24 06-03-2009 08:33 PM
A run down on suspension lifts.body lifts.spacers mightydog78 TJ Wrangler Technical Forum 5 02-27-2009 11:21 PM
coil spacer lifts on ebay carpekd TJ Wrangler Technical Forum 3 11-28-2007 12:44 PM
Body lifts/Suspension lifts OffRoadin'Lover TJ Wrangler Technical Forum 4 11-18-2006 01:57 PM
Spaced out over spacer lifts JeepDelaware TJ Wrangler Technical Forum 8 06-30-2003 12:55 PM
