Spacer lift failed? - JeepForum.com
 3Likes
post #1 of 18 Old 07-08-2016, 12:25 PM Thread Starter
frenchy206
Spacer lift failed?
I wanted to get your thoughts on what might have caused this issue.
I installed Teraflex 3/4" spacers on the rear maybe 2 years ago. I'd be surprised if I've put more then a few thousand miles on it since.
I noticed that my Jeep was listing to one side. I lifted the jeep up and found that most of the passenger side spacer was completely gone. Just a small chunk remained. The other side looks fine. What could have caused this?
03 TJ Rubicon
frenchy206 is offline
post #2 of 18 Old 07-08-2016, 12:45 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Engine torque spirals back to the passenger-side rear corner which will even cause that particular spring to sag before the others. I've had to replace the R-R spring on two TJs dues to that. I'd chalk it up to that, or that polyurethane spacer came out of a bad batch.
Jerry Bransford is offline
post #3 of 18 Old 07-08-2016, 01:11 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The spacer failed.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #4 of 18 Old 07-09-2016, 10:29 AM
durango-bob
2006 WK
It's been quite a while since I had a stock set of springs in my hands, but is it possible that the spring was installed upside down? I don't even remember if there is a difference in the the shape of the coil, I'm just tossing out ideas here.
durango-bob is offline
post #5 of 18 Old 07-09-2016, 11:28 AM
TheBoogieman
Devil's Advocate
TheBoogieman's Avatar
Originally Posted by durango-bob View Post
it's been quite a while since i had a stock set of springs in my hands, but is it possible that the spring was installed upside down? I don't even remember if there is a difference in the the shape of the coil, i'm just tossing out ideas here.
no.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #6 of 18 Old 07-09-2016, 05:53 PM Thread Starter
frenchy206
This makes sense. Maybe it was a flawed spacer. All the others seem fine and the Jeep has spent most of its time in a garage. Thanks for all the replies.
03 TJ Rubicon
post #7 of 18 Old 07-10-2016, 01:34 PM
KSBoilermaker
For what it's worth, I had a set of Teraflex 1.75" spacers on all four springs on my Jeep and, after several years, all four of them were collapsing and/or tearing apart under the springs. I contacted Teraflex and they do offer a lifetime warranty. Instead of doing 1.75" spacers all around again, I asked them to send me a pair of .75" spacers (I had added a hard top and wanted to use them to level out the rake and really didn't need the extra lift). The new spacers have been on for about a year and, yesterday, I noticed the passenger rear spacer was already starting to flex. I didn't check the driver's side but it could also support what Jerry was saying with the RR spring taking more abuse from the torque of the engine.
2000 Jeep Wrangler Sport -- it's green!
KSBoilermaker is offline
post #8 of 18 Old 07-15-2016, 01:44 PM
jeepinmike
I wonder if the heat from the exhaust contributes... I had 2 2" spacer collapse on the pass rear of my LJ over a few years. has BDS springs now.
jeepinmike is offline
post #9 of 18 Old 08-18-2017, 01:19 AM Thread Starter
frenchy206
Reviving an old thread.
Just wanted to update that today the other side failed. By failed, I mean disintegrated.
I decided to forget spacers and move to a small lift. Going to install OME 2" lift. Doing the HD springs due to all the skid plates, steel bumpers and winch.
Thoughts?
03 TJ Rubicon
post #10 of 18 Old 08-18-2017, 01:27 AM
TheBoogieman
Devil's Advocate
Thoughts?
New springs are always a good option. Seems like the HD would work well for your Jeep. I've never had a BB spacer fail, but I've never bought Teraflex either.
TJnBC likes this.
post #11 of 18 Old 08-18-2017, 01:45 AM Thread Starter
frenchy206
Deleted. Duplicate post.
03 TJ Rubicon
post #12 of 18 Old 08-18-2017, 01:51 AM Thread Starter
frenchy206
My hope is that it will level everything out with a slightly higher rear end. Anyone here have any experience with this particular lift?
03 TJ Rubicon
post #13 of 18 Old 08-18-2017, 05:50 AM
JEK3
JEK3's Avatar
OME has a pretty good reputation here. Your final ride height will, of course, depend on the combined weight of all your accessories.
JEK3 is offline
post #14 of 18 Old 08-18-2017, 10:19 AM
TJnBC
that would be a good choice.
IMO a coil lift is much better for handling/feel than a ****ty spacer lift. Get quality shocks
TheBoogieman likes this.
2006 LJR...the madness begins again
TJnBC is offline
post #15 of 18 Old 08-18-2017, 11:03 AM
aeroshots
FYI, I tried to fix the the tj lean with a name brand 1 inch spacer. It disintegrated too.
aeroshots is offline
