Quantcast Spacer install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Spacer install
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 05-08-2004, 03:54 PM   #1
river rat
Forum porn star...I guess
river rat's Avatar
Spacer install
Is there any easy way to install coil spacers? I installed a warn m8000 and now my front sags a little bit. I ordered 3/4 inch spacers, and was wondering what the easiest install method would be. Thanks, Troy.
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline   Reply With Quote
Old 05-08-2004, 04:27 PM   #2
TJandFSJ
easiest and only way I think:
Dis-connect front swaybar
Jack Jeep up and put jackstands on frame behind the lower control arms
Remove tire/wheels
Unbolt bottom of shock
Put jack under oppsite side of axle, and jack up the axle, like a flex which will cause the other side to drop more.
Pull spring out, take bump stop out
Put spacer on and put bump stop back on and put everything back together. Do the other side..
Took me about 1hr to do the front of my 2" BB.....
Did I forget anything?
TJandFSJ is offline   Reply With Quote
Old 05-08-2004, 05:25 PM   #3
BigWaylon
tubework is cool...
BigWaylon's Avatar
I had shocks removed to do my 2" BB...
but, I swapped springs a couple weeks after that, and did NOT remove or even unhook the bottoms of the shocks...
you will have to use the "jack up one side" method that way, or else get a loaner coil spring compressor from your local parts store...
you oughta be able to do it all in less than an hour...even if you unhook the bottom of the shocks (it's the top attachement that's a pain in the ....)
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote
Glock Forum
