Sounds like I have a flat tire, but only when slowing down... - JeepForum.com
post #1 of 14 Old 03-15-2009, 04:45 PM Thread Starter
Xander
I put the RC 2.5" on my Rubicon a week ago and it sounds like i have a flat tire when I decelerate. I didn't net the full 2.5", could it be the t-case? I really don't want to put the pucks under there (4 are being used under my seat ) because I would basically defeat the purpose of the lift. So, what do you think the noise could be?
'07STI
'12 WK2 Overland
Xander is offline
post #2 of 14 Old 03-15-2009, 07:05 PM Thread Starter
Xander
bump for nite crew...
'07STI
'12 WK2 Overland
Xander is offline
post #3 of 14 Old 03-15-2009, 07:06 PM
TJ-Driver
Need some more info. What does a flat tire sound like to you?
TJ-Driver is offline
post #4 of 14 Old 03-15-2009, 07:17 PM Thread Starter
Xander
"waa-waa-waa-waa-waa-waa" LOL
I hear it more from the rear and its mainly when the windows are up
'07STI
'12 WK2 Overland
Xander is offline
post #5 of 14 Old 03-15-2009, 07:29 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Could be a number of things, a u-joint that has more stress on it after the lift, axle bearing, pinion bearing, just gonna have to get under there and check things out.
xjfever is offline
post #6 of 14 Old 03-15-2009, 07:33 PM
Rocky529
Rocky529's Avatar
I'm betting on your rear drive shaft angle... you may need to drop the t-case. If you don't want to do that, installing a MML may help.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #7 of 14 Old 03-15-2009, 07:45 PM Thread Starter
Xander
Is it weird that I don't have any noticeable vibes when accelerating and only decelerating?
EDIT: can you do a mml without a BL?
'07STI
'12 WK2 Overland
Xander is offline
post #8 of 14 Old 03-15-2009, 08:06 PM
Rocky529
Rocky529's Avatar
Yes, you just have to raise your radiator one inch.
Rocky529 is offline
post #9 of 14 Old 03-15-2009, 08:08 PM Thread Starter
Xander
how? (10 char)
'07STI
'12 WK2 Overland
Xander is offline
post #10 of 14 Old 03-16-2009, 06:41 AM Thread Starter
Xander
Also noticed that I feel it when accelerating...but its not nearly as pronounced...
'07STI
'12 WK2 Overland
Xander is offline
post #11 of 14 Old 03-16-2009, 08:37 AM Thread Starter
Xander
I have also noticed a clunking/popping noise when I turn.....now i'm leaning towards U-Joints
'07STI
'12 WK2 Overland
Xander is offline
post #12 of 14 Old 03-16-2009, 08:48 AM
mitchf350
I wonder if it is tread seperation and the clunking my be your tire hitting your control arms. Cause when you lifted it your front axle may have shifted as did mine.
97 tj. RC. 2.5" 2.2 Shocks and steering stab. 31"x10.50x15 KM2's Safari straps full cage nets.
06 Commander 4.7l
mitchf350 is offline
post #13 of 14 Old 03-16-2009, 08:52 AM
bradthebard
Check for loose lug nuts. I had some sound just like that, no noise on acceleration, clunking on decelleration.
2000greenTJ
1954 CJ3B
"...Indeed I have burned the candle at both ends, and it gave off such a glorious light..." - Christopher Hitchens
Originally Posted by bradthebard View Post
Theology is one hundred blind men searching a dark room for a black cat that isn't there.
Originally Posted by schitzangiggles View Post
Atheism is one hundred blind men in a dark room claiming there is no black cat because they can't see it.
bradthebard is offline
post #14 of 14 Old 03-16-2009, 09:21 AM Thread Starter
Xander
i've been 'clunking' before the lift, but not as much and i'll have to check the tread.
'07STI
'12 WK2 Overland
Xander is offline
knocking when driving? sounds like a rock in tire but it isn't coolens98TJ TJ Wrangler Technical Forum 1 02-11-2010 04:22 PM
Flat tire mystery? CHRRRIS TJ Wrangler Technical Forum 13 08-13-2007 06:49 AM
Slowing down? (tire question) rick95 YJ Wrangler Technical Forum 5 04-14-2005 03:15 PM
a squeaky noise, sounds like it is near my tire. help? bono426 YJ Wrangler Technical Forum 3 12-06-2004 05:34 PM
Changing flat tire? Weiland TJ Wrangler Technical Forum 11 10-17-2004 12:43 PM
