I put the RC 2.5" on my Rubicon a week ago and it sounds like i have a flat tire when I decelerate. I didn't net the full 2.5", could it be the t-case? I really don't want to put the pucks under there (4 are being used under my seat ) because I would basically defeat the purpose of the lift. So, what do you think the noise could be?
Could be a number of things, a u-joint that has more stress on it after the lift, axle bearing, pinion bearing, just gonna have to get under there and check things out.
I wonder if it is tread seperation and the clunking my be your tire hitting your control arms. Cause when you lifted it your front axle may have shifted as did mine.
Check for loose lug nuts. I had some sound just like that, no noise on acceleration, clunking on decelleration.
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
