Soundbar Covering - JeepForum.com
post #1 of 6 Old 08-01-2007, 08:33 PM Thread Starter
twhditto
twhditto's Avatar
Soundbar Covering
I need to pick your minds. I took the soundbar (factory) out of my son's Jeep and cut the metal, and used MDF to make boxes to hold some 6X9's. I need to cover them with something. I am thinking about the speaker "carpet" or some other kind of thin carpet to go around it. Anyone got any ideas as to what will look better? There was some sort of fabric, obviously easy to wipe clean on it before with a cotton back, that was zipped on. We will probably use contact cement to put something over it to cover up the MDF and such. We are open to any and all suggestions. THANX!
2003 Rubicon, stock - but building - slowly... in Van Buren, AR
twhditto is offline
post #2 of 6 Old 08-01-2007, 08:41 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Isn't MDF board supposed to keep dry? I thought it will bubble the first time it gets water on it.... Oughta be fun first time your son gets it muddy or leaves the top down in a rainstorm.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #3 of 6 Old 08-01-2007, 08:46 PM Thread Starter
twhditto
twhditto's Avatar
Thanks for the reply. I have used MDF quite a bit, and have found that if it is correctly sealed - and we are not talking about a very big piece - just a small box on each end of the sound bar - that it will work fine. Now pressed wood is a different story! I use the marine grade polyurethane, after sealing the ends with exterior glue, slathering it down good. Plus, on top of that, there will be a good coat of contact cement. I built my soundbar - the whole thing - out of MDF four years ago, and it has seen its "wets" and drys. No noticeable problems yet. In fact, just last week, I took off one of the 6X9's to see if a connection had come loose - stupid FM radio station had a problem with its left channel - worked fine when I changed stations! And BTW, he does love the mud and wet! Maybe I ought to put turf down on it???
twhditto is offline
post #4 of 6 Old 08-01-2007, 08:50 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
... Turf may not be such a bad idea. How close is the factory covering to being able to fit? You could try to sew in some sort of extension for it, that way the part that faces the interior still looks factory.
Andy, KD8EIA
Grewe02 is offline
post #5 of 6 Old 08-01-2007, 08:50 PM Thread Starter
twhditto
twhditto's Avatar
PS - I forgot - when I got my speaker off, the MDF was intact and good as new - no signs of "weathering." But, I am also a 46 year old - old man!
twhditto is offline
post #6 of 6 Old 08-01-2007, 08:52 PM Thread Starter
twhditto
twhditto's Avatar
Andy,
That is not a bad idea about using the factory stuff. We are not talking about a huge addition either. I think I will hold on to it and see what I can come up with! But black turf may really look good too!
twhditto is offline
How do I get the dash covering off my 03? PearlJam1003 TJ Wrangler Technical Forum 4 12-19-2008 06:50 PM
Floor Covering OBK TJ Wrangler Technical Forum 2 04-24-2007 11:50 AM
Covering Air Vent mance YJ Wrangler Technical Forum 5 09-27-2005 03:28 PM
Covering up those Dings Optik45 TJ Wrangler Technical Forum 2 08-20-2004 07:02 AM
floor covering Dembones YJ Wrangler Technical Forum 19 01-08-2003 07:24 PM
