sound dampening the inside of a hard top? - JeepForum.com
post #1 of 10 Old 09-27-2007, 12:35 PM Thread Starter
archer75
I don't much care for the interior of the hard top, it's white. I'd like to darken it up by painting it but was thinking that I could try to find some sound dampening material and line it with that. Has anyone done anything like this?
archer75 is offline
post #2 of 10 Old 09-27-2007, 12:36 PM
Michael_K
Michael_K's Avatar
Yes I have.
Michael K.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline
post #3 of 10 Old 09-27-2007, 12:40 PM
garybattles
What materials did you use?
gmb08
garybattles is offline
post #4 of 10 Old 09-27-2007, 12:46 PM
Michael_K
Michael_K's Avatar
D-amplifier sound deadening mats and Hardtop liner by California top.
DailyDrivenTJ.com
post #5 of 10 Old 09-27-2007, 12:49 PM
highrisetj39.5
hardtop liner looks nice hows it do? really work well?
2000 Tj 4.7L supercharged, with a nv3500 and SYE np231. Currie Hp 9"s w/ 4.56 and arbs, rubicon express 4.5" SF, 1" BL, 35" BFG M/T, warn m8000, all custom armor, cage and bumpers front and rear with tire swing away, CB, Currie HD steering, and some other things
highrisetj39.5 is offline
post #6 of 10 Old 09-27-2007, 01:23 PM
rljsrubicon
Very Nice
I like that a lot.. Ron
Originally Posted by Michael_K
Yes I have.
Michael K.
rljsrubicon is offline
post #7 of 10 Old 09-27-2007, 02:41 PM
Sko
Michael K. - Looks good. Is it noticably quiter?
'06 Unlimited Rubi, auto, 6" LA, Dirt Logic shocks, 35" MTRs, 4.88's, ARB locker rear, stock Rubi lockers front, discos, Currie HD tie-rod, Jardine exhaust, OMF bead locks, Rock Hard sport cage, home made bumper/tire carrier, crusher corners, sliders, Fabtech front bumper, Superwinch EP9000, Vanco big brake kit, Lowrance GPS, Safari Straps nets,
Sko is offline
post #8 of 10 Old 09-27-2007, 03:04 PM
thesherm
thesherm's Avatar
for an easy job with a custom look and a lot cheaper, get 1/2" foam, a can of adhesive spray and the fabric of your choice at walmart or a fabric store.
i would post pics but my hardtop is buried in the back of the garage for another month or so.
98 Sahara
Originally Posted by mrblaine
Unfortunately you are one of those poor misguided folks that believes leaving the gear shift lever in one slot or another is an indication of control.
Come go for a ride and I'll be glad to demonstrate the difference between what you perceive incorrectly as "control" and what control actually is.
Pick a different reason because that one is both lame and stupid to perpetuate.
Pardon me for damaging your precious reputation. It's not that I disagree, that would be a difference of opinion. This isn't subjective, it's objective, you are just wrong. If you make that statement, you are misguided. It is that simple.
thesherm is offline
post #9 of 10 Old 09-27-2007, 03:04 PM
TheMightyGoat
Are you trying to reduce wind noise or what?
TheMightyGoat is offline
post #10 of 10 Old 09-27-2007, 03:26 PM
Michael_K
Michael_K's Avatar
I don't know. I have insulated the whole jeep, not just the hardtop.
Yes it is noticeably quieter than before putting in the insulation. I did sound measurement but I cannot find the excel file.
As far as I remember, my TJ used to hit 88db on highway. It is below 80 more like 76db average.
Anything above 85db will cause you to lose your hearing over time. I don't want to wear a hearing aid when I get old.
As far as putting thick insulation vs thin, you gotta understand that there are roughly two tasks when insulating, sound insulation and heat insulation. Heat insulation is accomplished by thick foam type material where it traps heat. Whereas when you are trying to quiet things down in a vehicle, you attach dense and relatively heavy material on surfaces where the vibration causing the noise. By adding more weight to the flat surface where it vibrates, more energy is needed vibrate. Adding more weight usually stops most of vibration.
Foam type is also used to absorb echoing within the vehicle. The hardtop liner was used for that purpose and to hide the insulation mat.
Michael K.
DailyDrivenTJ.com
Sound Dampening Advice fowlball TJ Wrangler Technical Forum 24 02-03-2010 04:28 PM
Moisture inside the hard top !! jeep2008 TJ Wrangler Technical Forum 6 12-30-2008 04:29 AM
Painting Inside Hard Top? 89MustangGX TJ Wrangler Technical Forum 7 11-06-2007 06:21 AM
Sound Dampening rickbo TJ Wrangler Technical Forum 1 09-21-2007 04:44 PM
Help getting paint off inside of hard top Stricken TJ Wrangler Technical Forum 4 11-16-2004 03:46 PM
