Sound bar installation help, pls!!! - JeepForum.com
post #1 of 12 Old 02-06-2008, 08:27 PM Thread Starter
VLT
1
VLT is offline
post #2 of 12 Old 02-06-2008, 08:35 PM
Rocky529
Rocky529's Avatar
Originally Posted by VLT View Post
Guys, if you could help me, I'd really appreciate it. My soundbar comes w/a light. The instructions state the RED wire = 12 Volt in....what does that mean and where do I connect this RED wire to?
Also, it says the GREEN wire = Remote light in...what does that mean and where do I connect this Green wire to?
Also, the soundbar, the stereo and the car wires all have a ground wire...can I combine them and ground them together?
Thanks much!
The red wire would splice into one of your other interior lights so it turns on automatically when you open the doors. If I'm not mistaken, you wouldn't have to connect the green wire if you go this route. The +12v wire may be constant hot though and may rely on a ground to trigger the lights to turn on... in other words the lights are hot and just rely on the ground to complete the circuit. You would have to connect the ground wire for the lights to the ground wire that your existing interior lights use in the Jeep.
The other grounds should be able to be spliced together and grounded together.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 12 Old 02-06-2008, 09:59 PM Thread Starter
VLT
Rocky, thanks so much for replying. You said, "The red wire would splice into one of your other interior lights so it turns on automatically when you open the doors." However, there are no interior lights on my jeep whatsoever. I bought this jeep used and the #4 fuse for lights is good, but there are no lights.
VLT is offline
post #4 of 12 Old 02-06-2008, 10:02 PM
DBLJ
DBLJ's Avatar
Do you have a soft top? Only Jeeps with a hardtop have another light that would come on with the open doors.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #5 of 12 Old 02-06-2008, 10:04 PM Thread Starter
VLT
Yes, it's a soft top so where would I connect the Sound Bar Red = 12 Volt in at?
VLT is offline
post #6 of 12 Old 02-06-2008, 10:19 PM
Rocky529
Rocky529's Avatar
Look in your door jams and you should see spring pins... those are the wires you want behind it.
Rocky529 is offline
post #7 of 12 Old 02-06-2008, 10:25 PM Thread Starter
VLT
Yes, I see the spring pins...do i take them out and is there just one wire that I connect the Soundbar Red wire to? thanks so much
VLT is offline
post #8 of 12 Old 02-06-2008, 10:37 PM
97tjtom
what i did for my interior light was i ran both wires down to my interior lights were (or for you, the wires connected to your door pins) and i just spliced them in with little blue wire taps. this way its controllable by the door and by turning the headlight knob to the left. do you even have sockets for the lamps right underneath the dash? if not pick some up from a junkyard and the plugs will be somewhere underneath. its a good thing to have.
Current: 1999 TJ 4.0 5 Speed
Past: 1999 XJ 4.0 Auto, 1993 XJ 4.0 5 Speed, 1997 TJ 4.0 5 Speed, 1994 XJ 4.0 5 Speed, 1993 Cadillac Sedan Deville 4.9L V8, 1991 Isuzu TrooperII 2.8L 5 Speed
97tjtom is offline
post #9 of 12 Old 02-06-2008, 10:42 PM Thread Starter
VLT
Thank you...I'll try that. Also, the wiring that came with the Jeep inside the stereo area, are 2 wire harnesses (one with colorful wires and one with dark wires). I think the dark wires are for the speakers, but don't I connect the soundbar and front speakers to the STEREO wires?
VLT is offline
post #10 of 12 Old 02-06-2008, 10:59 PM
97tjtom
do yo uhave the stock or aftermarket radio?
97tjtom is offline
post #11 of 12 Old 02-06-2008, 11:06 PM Thread Starter
VLT
Aftermarket stereo, but there are 2 sets of wire harnesses coming from the Jeep.
VLT is offline
post #12 of 12 Old 02-06-2008, 11:22 PM
97tjtom
you should have gotten a wiring adapter when you installed the stereo. if those 2 plugs go into one big plug and then connect to your stereo via another small plug, you might be able to read the wires on the adapting harness to find out which wire is for which speaker. otherwise your stereo owners manual will tell you what each wire is and then you can trace it from the back of the stereo and splice in.
97tjtom is offline
New Sound System: 6 1/2 speakers in sound bar?? Tips please mrbriteside1465 YJ Wrangler Technical Forum 2 11-08-2010 01:32 PM
Screeching sound. Sound changes with clutch movement. skream YJ Wrangler Technical Forum 10 04-20-2009 09:15 PM
overhead sound pod installation tjwrangler911 TJ Wrangler Technical Forum 0 12-25-2007 04:50 PM
Sound bar installation jgp TJ Wrangler Technical Forum 1 04-24-2007 03:58 PM
Sound bar installation? tklarer TJ Wrangler Technical Forum 6 07-18-2006 01:15 PM
