somethings wrong? - JeepForum.com
post #1 of 8 Old 08-31-2010, 08:05 PM Thread Starter
empirepball
somethings wrong?
Well I went to this little spot after school that my friend found. It pretty much was a path that went off the road and around a tree but has been rutted out by people driving through it, and it was hard/sticky mud with some big tree roots to go over, it wasn't all that difficult but I had to use 4 hi to get through most off the time, I have gone through it before in 2 wheel drive when it was very wet no problem but it has dried since then. I did not feel like I hurt anything but as I was driving home my steering wheel started to shake but not really violent, when I used the brakes it pulled to the left, when I had the steering wheel straight and took my hands off the steering wheel it pulled right. When I got home, I noticed that my front right end was smoking, I looked under and the smoke was coming from the front right brake rotor. Then I went to the gym and I heard a squealing when I backed up or pulled forward slow, and if I where to drive at 5-25mph I could hear a squeking noise coming from the front right. What could possibly be the problem or problems? I could only think of warped rotor, or loose suspension parts, or maybe the steering stabilizer is going bad. Also sometimes when i start the engine it hesitates. It's a stock 97 sport.
empirepball is offline
post #2 of 8 Old 08-31-2010, 08:16 PM
tjsean0308
my money is on a seized caliper. loose suspension parts shouldn't cause smoking only brake parts
tjsean0308 is offline
post #3 of 8 Old 08-31-2010, 08:17 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
sounds like your brake pads are sticking. probably because of divots on the slider. check there first.
Mail crawling.
MisfitSeven is offline
post #4 of 8 Old 08-31-2010, 08:17 PM
Barker540
I had something similar like that happen to me. The problem turned out to be a lazy caliper, and one day it just went. It would pull to one side, I felt like it was lagging when I tried to excelerate, and yes, it smoked too. After a little drive I got down and put the backside of my hand to the rim, but not touching it, and could feel how hot it was compared to the others. I put in a new set of calipers and it did the trick. I hope this helps.
Barker540 is offline
post #5 of 8 Old 08-31-2010, 08:23 PM
greenglazier
its a sticky caliper had the same problem smoke coming out an pulling, i had to drive like 15 miles like that and even burned my brake line hoses good thing its an easy fix, good luck
greenglazier is offline
post #6 of 8 Old 09-01-2010, 03:37 PM Thread Starter
empirepball
Well I drove to school, and back today. It drove perfectly fine. No pulling, shaking in the steering wheel, and when i used the brakes it behaved like normal so i dont know. Im geusing it was just mud on the brakes?
post #7 of 8 Old 09-01-2010, 03:39 PM
BriansCJ
1994 XJ Cherokee
I would guess mud in the brakes and the wheel(throwing it off balance)
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #8 of 8 Old 09-01-2010, 11:54 PM
2003RubiBlue
I don't think i've ever heard of mud in the brakes causing smoke to come from the front end. I would say that caliper is on its way out.
Will work for Jeep parts...
2003RubiBlue is offline
brakes , engine , stabilizer , steering wheel
somethings not right here... Billy YJ Wrangler Technical Forum 8 03-06-2010 10:33 AM
somethings wrong with the transmission...i think bluejeep2088 TJ Wrangler Technical Forum 2 12-15-2007 01:53 PM
somethings wrong bughunter YJ Wrangler Technical Forum 9 03-27-2007 12:32 PM
Somethings Broke Toasterovin TJ Wrangler Technical Forum 3 10-14-2006 08:04 AM
BAD MPG somethings wrong tomkirkland4 TJ Wrangler Technical Forum 9 07-23-2005 08:26 PM
