Something's leaking... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Something's leaking...
The Cure for your Tie Rod Roll!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINERô UV Permanent DIY Roll On Bed Line
Unread 08-04-2010, 10:31 AM   #1
ROLNOVR
Check engine light came on a couple days ago.
Something is leaking on the driver's side of the engine; kind of smells like power steering fluid. Shop tells me they can't diagnose it because my computer isn't communicating.
I'm going to take pictures when I get it back.
Any initial thoughts?
'97 RED TJ
ROLNOVR is offline   Reply With Quote Quick reply to this message
Unread 08-04-2010, 10:33 AM   #2
MC_NickP
see what the code is
Black 98 TJ
Low Output 4 Cylinder Jeep Club #178
build thread:
http://www.jeepforum.com/forum/f22/m...4/#post9499802
MC_NickP is offline   Reply With Quote Quick reply to this message
Unread 08-04-2010, 10:35 AM   #3
Smeg
I take it they can't diag the check engine light because of the computer not the leak?
Which engine?
Smeg is offline   Reply With Quote Quick reply to this message
Unread 08-04-2010, 11:09 AM   #4
mdm
Farm Wheeler
Leaking fluid that smells like power steering fluid, CEL coming on, 4 cyl engine has a power steering fluid pressure sensor,... Have you checked the power steering fluid level? Cleaning the area well will help you find the source of the leak.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 08-04-2010, 11:21 AM   #5
TheBoogieman
Psychotic Jeep Freak!
TheBoogieman's Avatar
Turn the key on and off 3 times and pull the code yourself.Your answer will be in the numbers grasshopper.When you find the code,time for you to leave.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 08-04-2010, 11:29 AM   #6
Ghaniba
That doesn't work on the early TJs does it?
Dave aka Ghan
'99 XJ ['98 TJ, '98 ZJ 5.9 Limited - Retired]
Member, Eastern4Wheelers.org
Ghaniba is offline   Reply With Quote Quick reply to this message
Unread 08-04-2010, 11:30 AM   #7
TheBoogieman
Dave aka Ghan
I think it only doesn't work on 98-99 TJ's.I think 97' had it.
Unread 10-03-2010, 10:15 AM   #8
ROLNOVR
Leak's been fixed (hoses and pressure switch). CEL is still on. Won't throw any codes with the ignition check.
If it's a problem with the computer, what do I do?
'97 RED TJ
Unread 10-03-2010, 10:55 AM   #9
VMI Jeeper
Does your cigarette lighter/outlet work? That and your CEL run on the same circuit. That fuse is most likely blown. I would check that fuse out.
VMI Jeeper is offline   Reply With Quote Quick reply to this message
Unread 10-28-2010, 09:40 PM   #10
JacKedUP4x4
i got a power steering fluid leak too, is there anything i might need to tighten to fix it? its not leaking a whole lot and stop leak has had no affect on it
JacKedUP4x4 is offline   Reply With Quote Quick reply to this message
Unread 10-28-2010, 09:59 PM   #11
rs4race
Dave aka Ghan
Yep it works. It will blink the code, and even show it in your odometer.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline   Reply With Quote Quick reply to this message
leak , engine , coolant , tj , wrangler
