Something went bang while articulating - JeepForum.com
post #1 of 13 Old 08-09-2010, 07:21 PM Thread Starter
gunnerbags
While i was driving diagonally down a hill and onto a driveway i heard this loud bang come from the rear end while in full articulation. I drove it home and it definately swayed and sagged in the right rear. Took a look today and found that the swaybar and links, coils, shocks were in good condition. But then i found that the upper and lower connecting arms (right terminology?) were all crooked and the bushings looked all messed up. Also I noticed that the rear was sagging and the axle was bumped 3/4" to the right. I am going to replace them but I am so perplexed that this happened and will just replacing them solve the problem or is there something else causing this? If anyone has had this problem I would really appreciate their input. Thanks!!
gunnerbags is offline
post #2 of 13 Old 08-09-2010, 07:26 PM
Sundowner
Sounds like you lost your track bar with that shift to the right. I wonder if that's not what racked your control arms out of shape.
Sundowner is offline
post #3 of 13 Old 08-09-2010, 07:41 PM Thread Starter
gunnerbags
It looks like the track bar has 2 bends in it; one halfway down the bar so it clears the exhaust and then one by the upper attachment point. Im not sure the second one is supposed to be there because if it is then that would def be why. Its just kind of funny that it went not doing anythign too extreme.
post #4 of 13 Old 08-09-2010, 08:07 PM
roundlitefan
roundlitefan's Avatar
check the welds on your track bar mounts really closely. You could have torn the bracket from the axle or the frame side.
roundlitefan is offline
post #5 of 13 Old 08-10-2010, 07:34 AM Thread Starter
gunnerbags
I compared my track bar to pictures I found online and the bends look like they are in the right places. The brackets look fine and I can't see any cracks or tears in the welds.
post #6 of 13 Old 08-10-2010, 07:38 AM
Sundowner
Pictures of the whole area, then. Someone'll spot the damage pretty quickly.
Edit: the only other thing that comes to mind would be a coil spring. If the rear is "sagging" and you're shifted to one side, you could have broken a coil and partially collapsed it. I know you said you checked that, but go over it again. Also check the upper and lower perches.
post #7 of 13 Old 08-10-2010, 07:48 AM
roundlitefan
I guess it could also be possible that you bent or sheared a CA bolt, and the pressure from the CA and bushing is holding the 2 halves in? Put a socket on everything and make sure nothing is spinning free.
post #8 of 13 Old 08-10-2010, 09:08 AM
BliZZard911
The loud bang is usually the rear anti-sway bar snapping. I know this because I've broken two so far, even with extended links. You may not be able to see it as they sometimes break in the bushing that's bolted to the frame (one on each side). This would explain the swaying after it broke.
I would bet money that this is what broke.
2000 Jeep TJ Wrangler - 4.0L, 5 speed standard - BONE STOCK FOR NOW
BliZZard911 is offline
post #9 of 13 Old 08-10-2010, 09:12 AM
Sundowner
Certainly possible...but what about the axle shift?
post #10 of 13 Old 08-11-2010, 03:29 PM Thread Starter
gunnerbags
Well I worked on it for a few hours yesterday making sure all bolts are tight on the CA's and disconected the track bar. The upper and lower brackets looked straight with good welds and the bar looked undamaged. I loosened the CA bolts again and banged the axel from the right until it was back in alignment and retightened the bolts. When I lowered the jeep and went to reconnect the track bar the bolt went in perfectly and the rear stayed in place. Yet the right rear still saggs a little bit and I think the sound I heard was from overcompressing the spring which I will be replacing tomorrow with a set of new ones. Hopefully this works as I believe it will.
post #11 of 13 Old 08-12-2010, 06:39 PM Thread Starter
gunnerbags
Wow! Replaced the coils in the rear today and the rear doesn't sag anymore. But once on the road the swaying was back. Turns out the swaybar link in the left front popped out of its socket less than a year after replacing them. Bought them from quadratec and they are the replacement ones....GARBAGE!! Lots of little things wrong from one thing letting go.
post #12 of 13 Old 11-06-2012, 12:42 PM
skorp1702
did you try the rugged ridge disconnects i have them on my cj and i tweek 1 tire 39 inches in the air all the time with the sway bar connected and disconnected. man they just just dont make them like they used to. also i know you said you realigned it but it might be a good an alignment done after you fix the sway bar connecting rods.
skorp1702 is offline
post #13 of 13 Old 11-07-2012, 07:38 AM
Diverdown87
Time for a rear AntiRock..
My idea of help from the man above is a sniper on the roof.
Diverdown87 is offline
alignment , axel , bushings , suspension
my YJ build "chitty chitty bang bang" bigrubbers4x4 YJ Wrangler Technical Forum 9 03-18-2009 10:29 PM
Strange bang JeepPirate TJ Wrangler Technical Forum 5 11-05-2007 08:51 PM
Bang 2JK JK Wrangler Technical Forum 1 05-27-2007 06:16 AM
Best articulating 5.5" lift? m1a convert TJ Wrangler Technical Forum 30 12-18-2006 10:10 PM
pop bang thchnheh TJ Wrangler Technical Forum 7 12-21-2005 09:39 AM
