-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Something went bang while articulating (http://www.jeepforum.com/forum/f9/something-went-bang-while-articulating-1086015/)
gunnerbags 08-09-2010 08:21 PM
While i was driving diagonally down a hill and onto a driveway i heard this loud bang come from the rear end while in full articulation. I drove it home and it definately swayed and sagged in the right rear. Took a look today and found that the swaybar and links, coils, shocks were in good condition. But then i found that the upper and lower connecting arms (right terminology?) were all crooked and the bushings looked all messed up. Also I noticed that the rear was sagging and the axle was bumped 3/4" to the right. I am going to replace them but I am so perplexed that this happened and will just replacing them solve the problem or is there something else causing this? If anyone has had this problem I would really appreciate their input. Thanks!!
Sundowner 08-09-2010 08:26 PM
Sounds like you lost your track bar with that shift to the right. I wonder if that's not what racked your control arms out of shape.
gunnerbags 08-09-2010 08:41 PM
It looks like the track bar has 2 bends in it; one halfway down the bar so it clears the exhaust and then one by the upper attachment point. Im not sure the second one is supposed to be there because if it is then that would def be why. Its just kind of funny that it went not doing anythign too extreme.
roundlitefan 08-09-2010 09:07 PM
check the welds on your track bar mounts really closely. You could have torn the bracket from the axle or the frame side.
gunnerbags 08-10-2010 08:34 AM
I compared my track bar to pictures I found online and the bends look like they are in the right places. The brackets look fine and I can't see any cracks or tears in the welds.
Sundowner 08-10-2010 08:38 AM
Pictures of the whole area, then. Someone'll spot the damage pretty quickly.
Edit: the only other thing that comes to mind would be a coil spring. If the rear is "sagging" and you're shifted to one side, you could have broken a coil and partially collapsed it. I know you said you checked that, but go over it again. Also check the upper and lower perches.
roundlitefan 08-10-2010 08:48 AM
I guess it could also be possible that you bent or sheared a CA bolt, and the pressure from the CA and bushing is holding the 2 halves in? Put a socket on everything and make sure nothing is spinning free.
BliZZard911 08-10-2010 10:08 AM
The loud bang is usually the rear anti-sway bar snapping. I know this because I've broken two so far, even with extended links. You may not be able to see it as they sometimes break in the bushing that's bolted to the frame (one on each side). This would explain the swaying after it broke.
I would bet money that this is what broke.
Sundowner 08-10-2010 10:12 AM
Certainly possible...but what about the axle shift?
gunnerbags 08-11-2010 04:29 PM
Well I worked on it for a few hours yesterday making sure all bolts are tight on the CA's and disconected the track bar. The upper and lower brackets looked straight with good welds and the bar looked undamaged. I loosened the CA bolts again and banged the axel from the right until it was back in alignment and retightened the bolts. When I lowered the jeep and went to reconnect the track bar the bolt went in perfectly and the rear stayed in place. Yet the right rear still saggs a little bit and I think the sound I heard was from overcompressing the spring which I will be replacing tomorrow with a set of new ones. Hopefully this works as I believe it will.
gunnerbags 08-12-2010 07:39 PM
Wow! Replaced the coils in the rear today and the rear doesn't sag anymore. But once on the road the swaying was back. Turns out the swaybar link in the left front popped out of its socket less than a year after replacing them. Bought them from quadratec and they are the replacement ones....GARBAGE!! Lots of little things wrong from one thing letting go.
skorp1702 11-06-2012 01:42 PM
did you try the rugged ridge disconnects i have them on my cj and i tweek 1 tire 39 inches in the air all the time with the sway bar connected and disconnected. man they just just dont make them like they used to. also i know you said you realigned it but it might be a good an alignment done after you fix the sway bar connecting rods.
Diverdown87 11-07-2012 08:38 AM
Time for a rear AntiRock..
The time now is 10:52 AM.
