Something in ignition going bad? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Something in ignition going bad?
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rockFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 02-13-2014, 08:12 PM   #1
TJJeepJosh
This started a few days ago. I'll get in and turn the key to start the jeep and nothing. no clicking no turning over nothing at all. Doesn't happen every time I start it but when it does if I let it sit or try a few more times sometimes it works. Other times it takes longer than that. Was thinking bad battery at first but other electronics work fine. Plus when it finally does start it fires up just fine. Would think with a bad battery it would need to be jumped. Could something be going bad in the key cylinder/ignition on the steering wheel?
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline   Reply With Quote
Unread 02-13-2014, 08:32 PM   #2
CBTJ
There is an actuator rod in the column that wears out......you should check that out. Its behind the plastic covers on the column
CBTJ is offline   Reply With Quote
Unread 02-13-2014, 08:40 PM   #3
Cuder
I think it's a #20 torx security bit to remove the ignition switch. You can remove the switch without taking everything apart to see if the end has broke.
http://www.jeepforum.com/forum/f9/ig...epair-1378503/
http://www.jeepforum.com/forum/f9/ig...epair-1184102/
My Build Thread:
http://www.jeepforum.com/forum/f22/c...-lift-1268317/
Cuder is offline   Reply With Quote
Unread 02-14-2014, 04:27 AM   #4
TJJeepJosh
Thanks I'll check that out when I get home today
Unread 02-14-2014, 10:14 AM   #5
rikkards
rikkards's Avatar
I have something similar happening. Not sure exactly but things to look at if you haven't already
- Ignition pin as mentioned, Dorman makes a replacement for like 20-30 bucks. Going through the dealer will cost you 800 as the replace pretty much everything involving the steering column
- Battery connections. Make sure they are clean and tight
- Starter Relay. I think you can swap out your horn or wipers (can't remember) and see if it works
- Starter. You can pull and get it tested but if it is intermittent they may not be able to replicate
- Grounds. There are a bunch
All that has been done and I still get it everyonce in a while
Dear Canada, F you - Ron Swanson
rikkards is online now   Reply With Quote
Unread 02-15-2014, 11:16 AM   #6
JeepSgt
Had the same problem. Ended up having to replace battery cables to starter as well as the ground wire and later the cable that runs to the power distro box. Internal wire corrosion was the problem.
JeepSgt is offline   Reply With Quote
Unread 02-15-2014, 12:30 PM   #7
rikkards
rikkards's Avatar
That is my next suspicion.
Unread 02-15-2014, 04:09 PM   #8
TJJeepJosh
Well I ordered the doorman actuator pin ignition switch so I'll install that and see how it works. If that doesn't fix it I'll have to look into other things.
Unread 02-20-2014, 08:45 AM   #9
TJJeepJosh
So I got the new part put it in and it seemed to fix it. But later on I drove over to a friends house and it took 3 turns of the key to start it there and then another 3-4 later at taco bell. Seems like if I push the clutch in really fast or hard before starting it helps. Also sometimes it begins to turn over and start then stops. Almost like something is loose or not connected entirely. Maybe a ground or a cable?
Unread 02-20-2014, 08:54 AM   #10
SomeBeach
Sounds like your clutch safety interlock switch is going bad.......
SomeBeach is offline   Reply With Quote
Unread 02-20-2014, 10:39 AM   #11
rikkards
rikkards's Avatar
Before going and replacing the Safety Interlock Switch there is a fuse you can put in to override it. I thought mine was the same and did the fuse trick but that wasn't it.
Oh and keep your old ignition switch. Now you have a spare. If the metal cage and the plastic pin looked ok then odds are it was never anything wrong with it.
Unread 02-20-2014, 11:35 AM   #12
SomeBeach
I agree, but it is another place to conduct your troubleshooting.....
Unread 02-20-2014, 01:44 PM   #13
rikkards
rikkards's Avatar
Difference between troubleshooting and throwing parts at it. I would bypass for a while and if it doesn't happen then replace
Unread 02-20-2014, 06:44 PM   #14
TJJeepJosh
When I took out the old switch I compared it to the new one and they looked exactly the same. Realized at that point that piece probably wasn't the problem. Ohwell I learned how to uninstall/install it and now have a spare.
As for the fuse, do you know which fuse it is or where it is that I can override it?
EDIT: After a quick search I found some threads on how to do it.
Unread 02-20-2014, 07:20 PM   #15
rikkards
rikkards's Avatar
I have two spares. My liberty uses the same switch as well. That one the cage had broken off at the tip so when the plastic pin went to go in it was being pushed to the side and not hitting the contact.
