Something acting weird with my steering in my TJ - JeepForum.com
post #1 of 6 Old 11-13-2010, 07:56 PM Thread Starter
Smitty98TJ
I was driving my Jeep yesterday when something just didn't feel right with the steering, at high speeds the steering would be very loose and unstable but at low speeds it was tight and still unstable, kind of like an old car without power steering. I checked the power steering fluid and it was fine, looked for leaks but couldn't find any. The steering stabilizer is a skyjacker replacement stabilizer that i put on about two months ago. Also when i would park the wheels would be straight but the steering wheel would be pointed down and to the left, when i would drive off it would straighten out, really weird, anyone have an idea of what it is? Thanks in advance.
http://www.jeepforum.com/forum/f22/1998-tj-sport-build-1097517/
Smitty98TJ is offline
post #2 of 6 Old 11-13-2010, 07:59 PM
fang_x
get an alignment done?
also have you been offroading lately?
i know i bent a tierod once and i was having stability issues, visually its hard to tell if it is bent unless your comparing it to another one, but since then i upgraded to a heavy duty one.
it may also be your balljoints on the knuckles, when they start to wear it makes it feel a bit loose
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #3 of 6 Old 11-13-2010, 08:03 PM Thread Starter
Smitty98TJ
I got the tires probably a month ago so they should be alinged, i have been offroading but it was still acting weird on the way to the actual offroading, i was thinking about the ball joints also.
post #4 of 6 Old 11-14-2010, 08:24 PM Thread Starter
Smitty98TJ
Anyone have an idea???????????????
post #5 of 6 Old 11-14-2010, 08:43 PM
nukegm426
new tires has nothing to do with the alignment, you should have it checked.
nukegm426 is offline
post #6 of 6 Old 11-14-2010, 08:50 PM Thread Starter
Smitty98TJ
what i meant was that when i got the tires i got them balanced and aligned, probably will run it by the tire shop tomorrow and get the alignment checked, any other ideas of what it is?
lifted , power steering , skyjacker , steering , steering stabilizer
HVAC acting weird... Juicehead TJ Wrangler Technical Forum 3 05-06-2010 05:05 PM
4.0 Acting weird Redneck924 TJ Wrangler Technical Forum 7 02-27-2009 01:59 PM
YJ acting a little weird.... Tallanasty YJ Wrangler Technical Forum 2 02-12-2008 11:26 AM
Air Conditioning Acting Weird jwomack TJ Wrangler Technical Forum 7 06-29-2007 10:19 PM
headlights acting weird johnWJ TJ Wrangler Technical Forum 7 02-26-2006 05:17 PM
