Someone with A to Z rockers help me out! - JeepForum.com
post #1 of 6 Old 04-06-2008, 09:59 PM Thread Starter
creepycrawly
creepycrawly's Avatar
I need someone with A to Z rockers to measure from the rear of the rocker to the very front of the tube step, please. I am trying to determine if I will be able to cut enough of the rocker off without getting into the step in order for it to clear the tube on my new fenders. Thanks.
You can't be first, but you can be next!
creepycrawly is offline
post #2 of 6 Old 04-06-2008, 10:19 PM
distantdog
Did you get the wheel well to wheel well ones?
Or will the standard ones be too long too?
distantdog is offline
post #3 of 6 Old 04-07-2008, 09:21 AM
Schwalby
Schwalby's Avatar
Measure the distance from the front fender where the tub ends to where the tube of your fender is. Also take a picture. then you can call Zach and give him the measurements I would bet anything he can answer you quickly or he can modify the rocker to work with your tube fenders. He has outstanding customer service and I am sure he will help you out.
Tattoos, women and Jeeps...... I need to find cheaper hobbies.
Great American Jeep Rally
Schwalby is offline
post #4 of 6 Old 04-07-2008, 04:21 PM Thread Starter
creepycrawly
Standard ones and they are still too long.
post #5 of 6 Old 04-07-2008, 04:23 PM Thread Starter
creepycrawly
I know they wont fit and I was going to call Zach and see if he could weld the step on maybe an inch to the rear, but I wanted to have all the info before I called and bugged him about it. I understand that he is running a business and has a lot of stuff going on, so his time is literally money!
post #6 of 6 Old 04-07-2008, 09:10 PM
redsoxski
redsoxski's Avatar
His business (and profit) is also dependent on customer service and reputation. I've never heard anything negative. I'm sure he'll be glad to talk it over with you and get you what you need, give him a call...
redsoxski is offline
Which rockers from q tec? $lick TJ Wrangler Technical Forum 15 08-03-2007 10:04 PM
Anyone use these rockers? mferrari TJ Wrangler Technical Forum 2 05-18-2006 07:31 AM
New rockers are on :-) Chris_L TJ Wrangler Technical Forum 3 03-04-2005 11:05 AM
Aev Rockers chris06 TJ Wrangler Technical Forum 23 01-16-2005 09:33 PM
AEV Rockers Builder15 TJ Wrangler Technical Forum 1 08-21-2004 09:43 AM
