Someone Please Help ME! My Air Wont Work! - JeepForum.com
post #1 of 3 Old 07-05-2012, 04:12 PM Thread Starter
WranglerNooby
I have a 1997 jeep wrangler 2.5L 4cyl. The air comes out of the defrost vent, the foot vents, and the top corner vents, but when i try to switch it to the middle "face" vents it wont come out. What trouble shooting steps should I take to either solve the problem or eliminate easy fixes? thanks
I took off the cover in front of the steering wheel and can see 3 actuators that seem to control the vents but there are 6 cables total and only 4 are being used by the 3 actuators. this leaves me to believe that there is a 4th one that i can not find. I have checked the Three i can see and they all have the cables on correctly and securely and move fine.
WranglerNooby is offline
post #2 of 3 Old 07-05-2012, 04:32 PM
catmechanic
Use the search function. This is only about a half page below your post.
http://www.jeepforum.com/forum/f9/al...roster-527339/
catmechanic is offline
post #3 of 3 Old 07-05-2012, 05:11 PM
Necko2529
If you are getting the air out of the windshield vents regardless of the switch setting, you more than likely have a vacuum leak somewhere in the engine compartment.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
a/c , problem , vents , wrangler tj
4wd wont work drpepper YJ Wrangler Technical Forum 6 05-16-2011 01:57 AM
need help!! 4wd wont work!!!! jordan_inc YJ Wrangler Technical Forum 10 12-12-2010 10:41 AM
90 4x4 wont work!! jake18 YJ Wrangler Technical Forum 7 06-24-2010 07:02 PM
my 4WD wont work... vball1socr4 YJ Wrangler Technical Forum 2 07-06-2003 06:07 PM
