some gauge cluster lights won't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > some gauge cluster lights won't work
Rough Country Lift Kits and Parts!Ruffstuff 10 year saleSmittybilt XRC M.O.D Bumper and Brush Guard
Unread 06-05-2009, 11:07 PM   #1
carsonvogt
When I got my Jeep I noticed that a couple (not all!) of the original bulbs weren't working, so I decided to do the LED swap. The same bulbs won't light up. I've searched the forum, but most of the problems appear to be the entire cluster not working. Could it just be contacts or the plugs into the cluster, or a fuse? I'm not very good with the electrical in the Jeep, so any help would be much appreciated. Thanks!
Originally Posted by MikeBK
No, we are definitely crazy, but this is where we come to remind ourselves we are not alone. Brothers in Jeep insanity.
Survivalist Club Member #26
carsonvogt is offline   Reply With Quote Quick reply to this message
Unread 06-05-2009, 11:14 PM   #2
TXjeepTJ
check the contacts of the bulb holder, if they arnt flared up they might not be getting a good connection. if that doesnt work, you should probably just buy a used cluster, you can find them on ebay ranging from $40 +
LS1 powered TJ
http://www.jeepforum.com/forum/f7/my-v8-swap-blog-updates-365293/
C6 Z06 Corvette
TXjeepTJ is offline   Reply With Quote Quick reply to this message
Unread 06-05-2009, 11:35 PM   #3
carsonvogt
Okay, I'll check that out. Right as you were posting I was thinking that I might change the holders around (don't know why I didn't think of it before) to see if they might be the problem. Still working on it. Thanks for your reply!
