some gauge cluster lights won't work - JeepForum.com
post #1 of 3 Old 06-05-2009, 10:07 PM Thread Starter
carsonvogt
When I got my Jeep I noticed that a couple (not all!) of the original bulbs weren't working, so I decided to do the LED swap. The same bulbs won't light up. I've searched the forum, but most of the problems appear to be the entire cluster not working. Could it just be contacts or the plugs into the cluster, or a fuse? I'm not very good with the electrical in the Jeep, so any help would be much appreciated. Thanks!
Originally Posted by MikeBK
No, we are definitely crazy, but this is where we come to remind ourselves we are not alone. Brothers in Jeep insanity.
Survivalist Club Member #26
carsonvogt is offline
post #2 of 3 Old 06-05-2009, 10:14 PM
TXjeepTJ
TXjeepTJ's Avatar
check the contacts of the bulb holder, if they arnt flared up they might not be getting a good connection. if that doesnt work, you should probably just buy a used cluster, you can find them on ebay ranging from $40 +
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #3 of 3 Old 06-05-2009, 10:35 PM Thread Starter
carsonvogt
Okay, I'll check that out. Right as you were posting I was thinking that I might change the holders around (don't know why I didn't think of it before) to see if they might be the problem. Still working on it. Thanks for your reply!
stock gauge cluster with a 5.3 swap - will it work? busterandnitro TJ Wrangler Technical Forum 13 10-30-2014 09:03 PM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 05:51 PM
gauge cluster lights Conti31 TJ Wrangler Technical Forum 0 10-30-2008 05:02 PM
Gauge cluster for 89 YJ, will any year work? johnrezz YJ Wrangler Technical Forum 7 10-05-2008 08:16 AM
'92 YJ Gauge Cluster - making it work w/ a 350 UCF YJ'r YJ Wrangler Technical Forum 8 03-21-2008 07:09 PM
