Quantcast Solution to steering wobble and death wobble...need help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Solution to steering wobble and death wobble...need help
Old 07-19-2005, 09:40 AM   #1
Sparty
SO.......here's an update.
2" of coil lift
1" MML
1" BL
Added a winch (~100 lbs with plate) and started to get a little wobble when front tires hit a bump in the road.
Took it to the dealer (with a good rep) and they said I need to do the following:
*Relocate the drag link.
Does anyone know anything about this? Where the hell do I relocate it? And how easy/difficult is it to do this?
*Upgrade steering stablizer to compensate the weight of the winch
Anyone know of a good one to upgrade to for the setup I have?
TIA!
Jeep Pics
www.msu.edu/~kerrrand/Jeep.htm
Sparty is offline   Reply With Quote
Old 07-19-2005, 10:09 AM   #2
HokieTJ
Has it been aligned since the lift? If not, you need to get that done. Chances are that's what's causing the wobble. IMO, with 2" of lift you shouldn't need to touch the drag link.
You can get an adjustable track bar, but with 2" of lift I doubt you need it. Get it aligned and see what that does for you.
I had the same problem after I put on my lift. It was a combination of bad alignment and track bar bolts that were not tight enough.
2004 Red Sport
3.5" RE SF Lift
33x12.50 BFG's AT's
LoD bumper/tire carrier
HokieTJ is offline   Reply With Quote
Old 07-19-2005, 10:13 AM   #3
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Ditto all the above, especially on the trackbar mounting bolts. But also make sure you get the tires rotated and balanced PERFECTLY. Once a Jeep is lifted, it becomes far less tolerant of an out of balance tire which can trigger DW.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 07-19-2005, 10:16 AM   #4
mdm
Farm Wheeler
The additional weight can make the jeep more sensitive to a slight out of balance on the front wheels.
A steering stablizer doesn't cure problems, but sometimes do a good job of masking problems. Get the problem fixed.
mdm is offline   Reply With Quote
Old 07-19-2005, 10:21 AM   #5
Sparty
thanks boys....appreciate it.
I'll get on that ASAP, and report back!
Jeep Pics
Old 10-01-2010, 08:25 AM   #6
crash3400
*witty banter!*
what they said. plus it doesn't hurt to replace the stock bushings (on everything possible) if you can. the stock rubber bushings, maybe not so much on an 04, begin to go bad and allow a lot of play.
crash3400 is offline   Reply With Quote
Glock Forum
