Solid covers on D30 & D35 - fluid capacity? - JeepForum.com
post #1 of 34 Old 02-04-2008, 12:52 PM Thread Starter
probesport
probesport's Avatar
I am about to do a fluid change on my TJ and in the process putting on Solid covers & lubelockers - what I want to know is, does my capacity change? How much lube should I be putting in? Is there a way to check the level with the fill hole moved up like it is or do I go with a fluid measurement?
Ken S.
I'll find you someday and when I do, you'll know its me.
probesport is offline
post #2 of 34 Old 02-04-2008, 03:21 PM
06WranglerX
Nope the fluid capacity is the same as with a stock cover, DO NOT overfill the diff or you will end up having diff fluid blow out the breather hose, and the fluid can foam causing a lack of lubrication on the gears, fill with the same amount of fluid as you normally would. If you have adjusted your Pinion angle for an sye/cv ds I have heard that you can put a little bit more fluid in to compensate for the adjustment but i really wouldn't advise more fluid then whats advised in the FSM.
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline
post #3 of 34 Old 02-04-2008, 07:30 PM
ptowntj
ptowntj's Avatar
I don't know what the dana 35 takes, but I know that the dana 30 takes around 11/2 quarts...be careful not to overfill, or you will have a big mess.
8 lug xj.
ptowntj is offline
post #4 of 34 Old 02-05-2008, 05:14 AM Thread Starter
probesport
probesport's Avatar
Thanks, thats what I was hoping to hear
Ken S.
post #5 of 34 Old 02-05-2008, 06:38 AM
SteelBlueTJ
How much does the rear D44 take? I want to change mine out this weekend, but I forget what it takes.
SteelBlueTJ is offline
post #6 of 34 Old 02-05-2008, 07:38 AM
bradleyfitz
4 pints (2 quarts) according to Stu.
http://www.stu-offroad.com/misc/maint.htm
98 Sahara, hp44/hp60, warn 5x5.5 premium hub conversion, 4.88, arb's, hydro assist, RE 4.5 SF /w 3.5 springs, Novak / Teraflex SS SYE, currie anti-rock, JKS 1.25" BL, 36" bias iroks, PSC Tube fenders /w 3" flare, PSC Ricochet Rockers, custom rear bumper, btf front bumper / winch plate, warn 9.5ti, full cage, TwistedStitch seats, RCI-2161a fuel cell
bradleyfitz is offline
post #7 of 34 Old 02-05-2008, 08:10 AM
06WranglerX
Here you go.
Axles:
Dana 30 - 1.25 quarts 80W-90
Dana 35 - 1.75 quarts 80W-90 or 75W-140 synthetic
Dana 44 - 2 quarts 80W-90 or 75W-140 synthetic
Rubi Dana 44 - 2 quarts 75W-140 synthetic
Thats from a post wheelin98tj made link here click me
post #8 of 34 Old 02-05-2008, 08:45 AM Thread Starter
probesport
probesport's Avatar
If I did synth (RP) in my 35/30 should I use 75/90 or 75/140?
Ken S.
post #9 of 34 Old 02-05-2008, 09:00 PM
06WranglerX
I run 75/140 because I wheel my jeep, so I wanted a thicker gear oil, however 75/90 is just as fine and would work as well. 75/140 is recommended in the FSM if you are going to be using your jeep to trailer anything, they also say that 75/90 is the reg for your diff if your not trailering anything.
post #10 of 34 Old 02-05-2008, 10:17 PM
ptowntj
ptowntj's Avatar
I run the 75/140, as that is what ARB recommends for offroad use. Royal Purple seems pretty good, its only a few extra bucks.
8 lug xj.
ptowntj is offline
post #11 of 34 Old 02-06-2008, 05:52 AM Thread Starter
probesport
probesport's Avatar
I do plan on a bit of wheeling, but realistically will probably only be able to get out a weekend per month over teh spring/summer/fall - do you recommend 75/140 or 75/90 then?
Ken S.
post #12 of 34 Old 02-06-2008, 07:29 AM
06WranglerX
Honestly it's really a choice up to you, I have had no ill effects with the fluid becoming heavy or thick in cold weather and like I said I am running 75/140, but I do not know how cold MI is getting this time of year.
post #13 of 34 Old 02-06-2008, 07:49 AM Thread Starter
probesport
probesport's Avatar
In the teens to early 20s, very little below 10. We will be back in the 30s again shortly however.
Ken S.
post #14 of 34 Old 02-09-2009, 05:35 PM
mrcleanstj
Hoping to do the axles on my tj this weekend.
I plan to use regular lube and agree with amounts listed above.
I plan to remove the covers to check things out. When reinstalling the covers is there a gasket to use or just rtv?
Question #2
Plan to drop the pan on the trans and change the filter. How much fluid will drain out?
A person once told me i was driving beyond the capabilities of my vehicle - obviously they never seen the capabilities of a jeep!
This space saved for info:
mrcleanstj is offline
post #15 of 34 Old 02-09-2009, 06:38 PM
2jhanna
just fill until the fluid is level with the bottom of the fill hole. that's it.
jhanna
denton county, tx
2jhanna is offline
Solid diff covers kllrbee TJ Wrangler Technical Forum 4 12-16-2009 08:04 PM
Solid diff covers asa TJ Wrangler Technical Forum 9 01-26-2009 11:26 AM
Solid Dif Covers rubijksilver JK Wrangler Technical Forum 3 11-02-2008 03:16 PM
Solid Diff Covers JEEPMSA TJ Wrangler Technical Forum 3 12-29-2007 04:56 PM
SOLID diff covers... thejafe TJ Wrangler Technical Forum 62 04-01-2007 03:07 PM
