Solid Axle Hd 44 Rear Axle Assembly - Page 7 - JeepForum.com
post #91 of 129 Old 02-12-2009, 10:53 PM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
Update to an old thread...
I freakin' HATE dealing with the Wilwood Brakes on this Axle...
I emailed Solid Axle...they said that most customers are happy with them and I need to call Wilwood, don't bother us, goodbye... I contact Wilwood, they first tell me they don't make kits for Jeeps ...followup with "well those pads shouldn't be making that much noise, and the braking "should" be much better... I tried removing the potential "glaze" (that I didn't really see) from the pads and rotors, re-bed per their recommendation... made everything worse...horrible smell coming from the pads, and the ear splitting squeal is pretty much any time I touch the brake pedal regardless of speed or pressure.
So far I've replaced the Calipers (had some "sticking" early on), a shattered caliper bracket and I have a set of pads on order... I have more $$$ into this kit than what an entire replacement disc set would cost.
I'm "this-close" to giving up on these things... SO frustrated...These things just suck balls and I'm tired of dealing with them...
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #92 of 129 Old 02-13-2009, 06:27 AM
V-8unlimited
Man, glad I came upon this thread, I've bee looking into solid axles for my Jeep, but will for sure keep the willwood brakes from being shipped to me.
V-8 wrangler:
V-8unlimited is offline
post #93 of 129 Old 02-13-2009, 07:47 AM
bradleyfitz
Technically, they don't. They make brake kits for a D44 that went into a Jeep. I wish I had something to say other than the wilwood brakes on my Solid HP60 work fine. Hopefully someone with brake knowledge can chime in and offer some suggestions.
I would keep calling Wilwood. "No one else has a problem" is not exactly customer service.
98 Sahara, hp44/hp60, warn 5x5.5 premium hub conversion, 4.88, arb's, hydro assist, RE 4.5 SF /w 3.5 springs, Novak / Teraflex SS SYE, currie anti-rock, JKS 1.25" BL, 36" bias iroks, PSC Tube fenders /w 3" flare, PSC Ricochet Rockers, custom rear bumper, btf front bumper / winch plate, warn 9.5ti, full cage, TwistedStitch seats, RCI-2161a fuel cell
bradleyfitz is offline
post #94 of 129 Old 02-13-2009, 08:02 AM Thread Starter
SuperWade2
SuperWade2's Avatar
First couple pages of the thread...VanCo, MrBlaine and Jerry B all "suggested" that there might be problems... I just didn't listen...
Sw2
Does anyone know if this might be an option as a replacement?
http://www.currieenterprises.com/ces...E.aspx?id=1229
2017 WK2 Overland
post #95 of 129 Old 02-13-2009, 10:24 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Sw2
Depends one what housing end bolt pattern you have.
That style of brake is available for two housing end bolt patterns. The ones from Currie use the Ford Big bearing housing end pattern and are the same as on the Ford Explorer 8.8.
It's also available in the Dana 44 housing end bolt pattern from the back of a TJ or Liberty.
If you can get in touch with Solid and ask them what bearing is in the housing end, that will get us much closer.
Set 10 is D-44
Set 20 is Ford 9" or 8.8
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #96 of 129 Old 02-13-2009, 10:26 AM Thread Starter
SuperWade2
SuperWade2's Avatar
Set 10 is D-44
Set 20 is what Matt @ Solid has set before...
2017 WK2 Overland
post #97 of 129 Old 02-13-2009, 11:10 AM
crusty1007
Whats up with the willwood calipers.
We use them on our desert car with no issues. unless of course you bend a rotor and it melts the caliper.
Are they shimmed properly?
is the proper thickness rotor being used?
What master cylinder?
proportioning valve?
so on......
crusty1007 is offline
post #98 of 129 Old 02-13-2009, 11:28 AM
Vancopbs
so on......
Most racing vehicles using wilwoods do not have power brakes, which is how Wilwoods are designed. Put a booster behind them and bad stuff happens. Put my hydroboost behind them and BOOM.
If you check out wilwood you will see they don't recommend pressures beyond 1000-1,100 lbs.
Manual Brakes: 700-900 Max Lbs of pressure
Power Brakes Single Diaphragm: 1,000-1,100 Max Lbs of pressure
Power Brakes Dual Diaphragm: 1,300-1,600 Max Lbs of pressure
Hydroboost Brakes: 2,000-3,000 Max Lbs of pressure
Now let's take this a bit further. If you're running a working stock proportioning valve (Stock meaning you did not modify it, Stock meaning it's not adjustable, Stock means it came in your vehicle originally). Then you can take those max pressure down 25-40%.
Example: You have a TJ stock booster and master cylinder, you are putting out 1,600 lbs of pressure to your front calipers. You are using the stock proportioning valve so take away 25%-40% for the rears. So, your TJ rears are seeing 960-1,200 lbs of pressure. That's right around where willwood wants you to be, in most cases putting them on the rear axle is fine.
"That's exactly what I did, why am I having a problem?"
Several possibilities.
1. It's not a stock valve, you took internet advice and either removed the o-ring and/or the spring of your valve, you're now getting the same (or close to) pressure to the back as you are to the front. You screwed yourself.
2. The prop valve isn't functioning.
3. You think you have a stock valve but are not the original owner, it's been changed out, screwed with or maybe even an adjustable now.
4. You're booster is just a screaming *** booster and putting out more pressure then usual (yeah, it happens).
This is all kinds of silly considering there's several kits out there using Original Jeep rear disc brakes or Ford rear disc brakes that don't have these problems at all. The best advice I can give anyone is this, if you're planning on using or are using power brakes, don't use Willwood calipers.
Van
Vanco Power Brake Supply
9738 Atlantic Ave
South Gate, Ca 90280
800-256-6295
323-563-1588
Vancopbs is offline
post #99 of 129 Old 02-13-2009, 11:42 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Set 20 typically fits the Ford housing end that the Currie Brakes bolt up to. The only issue will be the axle bearing offset to make sure the rotors line up in the caliper brackets.
I am Savvy
post #100 of 129 Old 02-13-2009, 12:15 PM Thread Starter
SuperWade2
SuperWade2's Avatar
I'll take Door #1 (and or #3) for the Loss, Van...
The shop that installed the Axle and Brakes removed the o-ring and installed a Wilwood Prop Valve...Shop #2 removed prop valve and verified that the ring was in fact gone...
So neither of these were "screwing myself" exacltly, expect for maybe for taking my Jeep to shops who didn't know about these brakes...
Option 1 - Get New Pads, continue to futz with these things and never be happy with the way they perform...
Option 2 - Get the Axle Bearing Offset for my Axle (I have the Kit # of the Wilwoods, should I be able to match that offset), **** Can the Wilwood's and get an Explorer Disc Kit (will I still have probs since I now have a "modified" stock valve...?).
2017 WK2 Overland
post #101 of 129 Old 02-13-2009, 12:21 PM
Vancopbs
Depends on the money, I don't sell any of this crap so I don't know the costs. I see you having two options.
1. Get a new stock prop valve installed the way it originally was and replaced all the bad **** in the rear.
2. Buy a Ford or Jeep rear disc kit. At that point I'd put the adjustable back on (if it's not there), but the stock is still better assuming you're street driving.
What I would do? I'd buy the Currie stuff if it will fit since everything Currie is awesome (my opinion) and the stock valve.
Van
9738 Atlantic Ave
800-256-6295
323-563-1588
Vancopbs is offline
post #102 of 129 Old 02-13-2009, 12:24 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you get serious about this option, I can measure my spare axle that has the Set 20 bearings on it and help you figure out what's needed.
I am Savvy
post #103 of 129 Old 02-13-2009, 02:07 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Yah, after this weekend of Snow wheeling up in the Sierra's, i'm ready to dump these things...the wet snow is making them suck even worse than dry... I'm ready to be done with them...
2017 WK2 Overland
post #104 of 129 Old 02-14-2009, 07:17 AM
Fat Chili
Solid Axle Customer Service - What's that? (Oh! but they pride themselves on it )
Just in case your not aware Solid Axle Australia and Solid Axle in the US are one in the same, their diff covers and centres are made over here; then shipped to you guys for assembly. Apparently the tubes, knuckles etc for the diffs assemble in Australia come from the US.
Here's a few Aussie experiences (I'm not saying that the US side of Solid is the same? They have actually helped out in resolving a situation that I am aware of ~ with the poor service on the Aussie side of the World);
http://www.ausjeepoffroad.com/forum/...ighlight=solid
It's good how they undercut the prices of their own retailers
And theirs some of the Rockcrusher / Solid saga here (bottom of page 2) - http://www.ausjeepoffroad.com/forum/...ad.php?t=65168
Do illiterate people get the full effect of Alphabet Soup?
2000 TJ - with stuff.
1949 CJ3A - the project
Come visit the Aussie Jeepers at
Fat Chili is offline
post #105 of 129 Old 02-14-2009, 07:36 AM
never monday
after the dust settles. If you want rid of the Wilwoods, find me.
never monday is offline
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
88 yj rear axle assembly? kp61man YJ Wrangler Technical Forum 2 02-14-2009 02:12 PM
Solid Axle Diff Cover mud n rox TJ Wrangler Technical Forum 12 11-11-2007 02:02 PM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 02:23 PM
D44 axle assembly TAMUJeep TJ Wrangler Technical Forum 0 03-03-2007 09:17 AM
