Solid Axle Hd 44 Rear Axle Assembly - Page 4 - JeepForum.com
post #46 of 129 Old 06-14-2007, 12:47 AM
jeepteejay
Originally Posted by Jerry Bransford
I wouldn't bother wasting $$$ or much thought energy over which rear brakes to install that rear axle. Rear brakes provide such a low percentage of the overall braking, 10-20% at most, that it just doesn't pay to spend big $$$ or waste a lot of time worrying about rear brakes. In the rear, heck, even old technology drum brakes still work very well.
Now if this were for the front axle, yeah upgrading the brakes is very much worth extra $$$ and time to upgrade them.
Yeah, this what is what I'm thinking. Which is why I'm wanting to keep stock brakes back there if I can. Either that, or something non-custom, that I can pick up at the auto parts store.
I'm probably going to have to contact them on this. Hopefully get a cahnce to later today.
Nobody ever answered the question as to: if the Wilwoods aren't strong enough to handle stock pressures, why they'd be used?
jeepteejay is offline
post #47 of 129 Old 06-14-2007, 06:55 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
the R&P is still D44 tho. for that price you might as well put that tubing and beefy alloy stuff in a 9", D60 or better yet, 9/D60 hybrid.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #48 of 129 Old 06-14-2007, 07:18 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The only reason you could get away with it is because the pressure to the rear brakes is not as high as to the front.
Max to the rear is more than likely right around what they can handle due to the prop valve.
But if you're interested, I have a complete set I adapted onto TJ knuckles that I removed from my wife's rig.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #49 of 129 Old 06-14-2007, 07:21 AM
jeepteejay
That price?
Find me a complete bolt in (or even anything remotely close to bolt in) like what you mention for $3G's.
Pricing regular D44's with an ARB and brakes usually hits near 3 everytime I look.
post #50 of 129 Old 06-14-2007, 09:45 AM
tjgoose
Originally Posted by TJeeper
I've been wondering the same thing (see second post). I would guess the 35 spline shaft is too large for the standard backing plate, which wouldn't allow the ZJ/TJ brakes to bolt up without major modifications.
Stock brakes (I have drums) bolt up just fine. I installed Alloy 35 Spline shafts and an ARB in my 44 just a couple of weeks ago.
'02 /RE 3.5 springs / Clayton LA / JKS 1.25" BL / M.O.R.E. 1" MML / SwayLock / Tera Low 2- Low / D30 with 4.56 & ARB / D44 with 4.56, 35 spline Alloy & ARB / 36" Iroks on Trail Ready Beadlocks / Shrockworks Rockers / 33 Engineering Belly-up / AA SYE and TW CV / Currie Steering / TNT fenders Corners / CJ Mirrors / RE Hand Throttle / Uniden Pro 510XL & Firestik
tjgoose is offline
post #51 of 129 Old 07-03-2007, 10:48 AM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
New HD D44 "Goodness" being installed as we speak!
SW2
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #52 of 129 Old 07-03-2007, 11:37 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
SW2
That's very nice looking. You might consider getting a 90 degree fitting that screws into the caliper and pointing the brake line at the axle tube to keep it out of harm's way.
BTW- I looked at the Wilwood parking brake assembly yesterday and it's a copy of Ford Explorer rear assembly. The only thing you need to be careful of is to keep an eye on the caliper mount bolts. The backing plate is aluminum and they loosen from time to time and need to have new loctite applied to the cap screws and re-tightened. Other than that, it's a good part.
I am Savvy
mrblaine is offline
post #53 of 129 Old 07-03-2007, 01:12 PM
yellj
SW2
Might want to get button head bolts for your cover, the bottom 3 get round down and you can't always get a socket on the other ones, at least on my Rockcrushers
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
yellj is offline
post #54 of 129 Old 07-03-2007, 01:18 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Any other *NEW* thoughts?
SW2
http://www.ok4wd.com/index.php/catal...ing_for_jeeps/
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #55 of 129 Old 07-03-2007, 02:37 PM
Unscathed
I'd rather spend the 3k for a D60, with an ARB custom fitted, then the solid D44..
(Being built as I type)
Best Axles and service you will find.
The owner of Alljeep.com, Wayne Hartwig will work within your budget!!! He is very informative to anyone not knowing much about axle work and will meet or beat any competitor's advertised price on any specific product delivered to your door - even if he sells at cost!
Unscathed is offline
post #56 of 129 Old 07-03-2007, 02:45 PM
Northridge4x4
Vendor
Northridge4x4's Avatar
What is a custom fitted arb?
866-601-5340
Your Trail Starts Here
FREE SHIPPING ON ALL ORDERS OVER $70
Northridge4x4 is offline
post #57 of 129 Old 07-03-2007, 08:25 PM
BoHeck
i hope they are all custom fitted...
1999 TJ 4.0 manual 4.88 on 35" Pro Comp Xtreme Muds/RE 4.5" lift 3.5" springs - RE mono shocks/Dana 44 locked with ARB - Alloy USA shafts/AA SYE Tom Wood's DS/AtoZ Fab Rockers/ 60" Hanson Prerunner Style Front Bumper/Jeeperman Rear Bumper Swing Away with Side Extensions/Bestop Sailcloth tinted/Roundeyes/Infinity Sound System
BoHeck is offline
post #58 of 129 Old 07-03-2007, 08:42 PM
McLovin
How much clearence will you loose though by going with a dana 60? I'd also like to see someone come up with the price of a shaved Dana 60 with alloy shafts, rear discs, ARB, Diff cover and 60" WMS to WMS. Seriously I'm not sure of the price but I can't imagine one being cheaper then that 44.
McLovin is offline
post #59 of 129 Old 07-03-2007, 08:53 PM
bryans98tj
I'll keep my 8.8 with alloy shafts for much cheaper thank you. That is a seriously nice axle though.
98 TJ-bought-not built
كافر - Infidel
bryans98tj is offline
post #60 of 129 Old 07-03-2007, 08:57 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Not that anyone cares, but I have to get new Upper Control Arms in order to get the pinion angle right... so with the Holiday, it looks like Thursday before the Axle Install is finished...
Also needed newer style E-Brake lines and I think I'm going to go ahead and do the Adj Rear Track bar at the same time...
Uggg, an extra $400-$500 that I wasn't planning on, but I guess it's stuff that I was going to eventually install anyhow...
SW2
2017 WK2 Overland
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
88 yj rear axle assembly? kp61man YJ Wrangler Technical Forum 2 02-14-2009 02:12 PM
Solid Axle Diff Cover mud n rox TJ Wrangler Technical Forum 12 11-11-2007 02:02 PM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 02:23 PM
D44 axle assembly TAMUJeep TJ Wrangler Technical Forum 0 03-03-2007 09:17 AM
