Solid Axle Hd 44 Rear Axle Assembly - Page 2 - JeepForum.com
post #16 of 129 Old 06-05-2007, 09:30 AM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
Originally Posted by Jerry Bransford
You've heard my thoughts about an axle that heavy for your anticipated tire size and wheeling needs, I won't repeat them other than to say I'd go nothing bigger than 33 spline and lose the 1/2" thick axle tubes.
I respect your opinion Jerry, but my thought process is that someday *maybe* I will goto some larger tires 35"+ and trailer this thing around and do some serious stuff... I just don't know yet... so for me, it's worth a fairly nominal amount of money (just a couple hundred $$$ by my estimation) to already have this thing in the event that I do.
Yes, the weight is an issue... but the trade off for a few extra lbs vs. the reduced chance that I'll ever have to swap the axle again is very tempting. It's not like I care about my gas mileage (otherwise I wouldn't drive a Jeep)...
*** EDIT ***
FYI, the Solid HD D44 Axle is 275 lbs per them, and David@Northridge4x4 said ~175-200lbs for his D44 Assembly...
*** EDIT ***
SW2
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #17 of 129 Old 06-05-2007, 10:16 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I won't beat this dead horse any longer but here's just a last couple of thoughts. And my weight concern had nothing to do with anything but just plain general trail performance.
Two weekends ago, there was a TJ in front of me doing a very tough trail with a very nice but heavy set of axles. They were really just plain too big & heavy for the 35" tires he was running. He was getting high-centered way too often with them and he struggled most of the day. For his $8,000 in axles, he wasn't doing as well as I was right behind him.
And then the lightweight stripped down Toyota truck that was behind me was the only vehicle in our group to make it up a waterfall that the rest of us had to winch up. His lighter weight gave him a real advantage over the rest of us.
I never really thought about weight that much until I started doing some tougher trails and wow, I was surprised how much difference a little additional weight makes. I now remove everything I can before a tough trail and the difference is definitely very noticeable. Unsprung or not unsprung weight.
I'm done here, I really don't mean to beat a dead horse so I apologize if this is getting to be too much... but there really is just a point where some axles are just too heavy for the application and I think that particular one is in this case.
This photo doesn't prove anything but it sure bugged the 14 Jeep owners in our group when that lightweight Toyota following me made it through everything without much trouble including not needing the winch at this waterfall where everyone else did. I hooked the winch up right after this photo was taken. His lighter weight really made a difference, though his slightly longer wheelbase helped at times too.
Jerry Bransford is online now
post #18 of 129 Old 06-05-2007, 10:16 AM
XtremeJeep
Speaking of the "never needing to upgrade", in that price range of $3k isnt a dana 60 from dynatrack a better option?
2004 TJ | 5'' on 35x12.5's | Currie HD Steering| Smittybilt tire carrier | 4.56's |
1988 XJ | 6'' on 33x12.5's | Locked and Loaded |
Originally Posted by bobbert350
you have to stop thinking of miles per gallon its fun per gallon....and in my jeep my fpg is too much to count
XtremeJeep is offline
post #19 of 129 Old 06-05-2007, 10:23 AM Thread Starter
SuperWade2
SuperWade2's Avatar
I got a quote from Dynatrac and it's about $4200+Shipping for a similarly setup D60...
2017 WK2 Overland
post #20 of 129 Old 06-05-2007, 01:27 PM
Kerndone
I lack money
Kerndone's Avatar
You really think that axle would be a good option for 38"-40" tires? Sure its beefy, but I didn't see anything about them including a magical ring and pinion or what size axle shaft bearings it uses. Not saying its a primed grenade, but the R&P is the weakest link in that housing, which is still just a D44. Is it a good deal for what you get...sure is. Is it a good deal for what you need? You will have to answer that question.
-Frank
Red Jeep Club Member 111
'99 TJ - work in progress...see profile
'08 WK - Silver RME, DD.
Kerndone is offline
post #21 of 129 Old 06-05-2007, 01:41 PM
big97redtj
-Frank
The axle uses set 20 bearings (Ford big bearing).
big97redtj is offline
post #22 of 129 Old 06-05-2007, 01:52 PM
Kerndone
I lack money
Kerndone's Avatar
Thats good to know, I was doing the "math" and I figured they needed to be bigger than set 10 bearings.
Kerndone is offline
post #23 of 129 Old 06-05-2007, 02:31 PM
Elusive
I have some experience with all of this.
point 1.
You can NOT build this axle for $3k. here is why:
the RD 109 ARB retails for over $900
alloy USA sells the shafts for $300
a TJ housing OR 8.8 with the bracket kit is going to be about $800
gears, bearings, seals brakes etc. and you are over $3k even DIY junkyard axle.
point 2.
I have a TJ on 35" krawlers and I wheel it very hard very often. I ran chromoly 30 spline shafts for 3 years till I broke one on jackhammer, them the next week one on Duran falls. 3 years is a VERY good amount of time for anything in my drivetrain to hold up, but the 4.56 gears were 6 years old and still fine. because of this, I put in the RD 109 and alloy USA 35 spline shafts into my TJ D-44. I expect that the ring gear is now the weak link in the axle, but the entire axle is much stronger than it was.
point 3.
The 14 bolt has it's place, and that place is next to 40+ inch tires on a full size rig. stock rear d-60 shafts are much weaker than chomo 44 shafts, and the center section hangs down an extra inch or so.
weight...
I would rather not break than be light.
The picture shown is the first waterfall on pumpkin eater. toyatas all walk up it and 93" wheelbase rigs all struggle... just like on every other waterfall in the world..wheelbase rules. Strange thing about that waterfall.. sometimes I make it, sometimes not. I don't know why. I have seen stripped down trail buggies climb things i could not make it up only because of wieght (the waterfall on backdoor especially), but I have no desire to strip the 1000 pounds off my TJ needed for that. I like the body, seats, and all 6 cylinders. i also like the crusher corners, skid plates and HP 44 with 1/2" tubes in the front. I built a lighter front 44 with TJ axle tubes and it bent in the center of the long tube in about 2 years.
I couldn't agree more with they guy that said "for an extra $400 why would you not do it?"
I think this axle is an excellent deal and would hold up fine to tires in the 37-38" range
I install gears!
lots of gears
gears that make you go, gears that make you slow.
Elusive is offline
post #24 of 129 Old 06-05-2007, 03:21 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Thanks for the input!!!
SW2
2017 WK2 Overland
post #25 of 129 Old 06-05-2007, 05:33 PM
McLovin
Thats what I was going to say. I know lots of full size guys that are getting away with running 38's on that style of 44. They aren't even using 35 spline shafts either. Very rarely do they have problems with the ring and pinions.
McLovin is offline
post #26 of 129 Old 06-10-2007, 09:36 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Just curious if there were folks out these that have ordered or are considering getting this axle...
Wonder how many Solid is building and selling?
I'm seriously considering still...
SW2
2017 WK2 Overland
post #27 of 129 Old 06-10-2007, 09:56 PM
Flatbroke
Superwade,
I bought a read axle assembly from Northridge. I works great. That being said, I would not hesitate to buy the axle you posted. It seems like a great buy.
I am toying with the idea of going full width, been tossing it around for a while now, but getting closer to making a decision.
Yellow 02 Sport
Originally Posted by XRussoX
Haha
I actually look at a Jeepers nuts to see how informed they are. Ditch your nuts man!
Russo
Flatbroke is offline
post #28 of 129 Old 06-10-2007, 10:22 PM
natehate
have you considered building a ford 9"
the currie housings are pretty cheap and strong
youd end up being pricier then that 44 but alot stronger and a bit liter and a bit better ground clearence
natehate is offline
post #29 of 129 Old 06-10-2007, 10:30 PM Thread Starter
SuperWade2
SuperWade2's Avatar
I'm not building anything... I'm a bolt-in guy... Flame me all you want...I don't' have the time, energy, patience, tools, etc to do much of this work... I have the money and don't' mind paying other people to make superior products that I can just bolt in myself.
That's why I was looking at the Norhridge4x4 Axle or this one... the Dynatrac and Currie completes were up over $4000/ea...I didn't really want something used, so was only considering new complete bolt-in assemblies.
Sw2
2017 WK2 Overland
post #30 of 129 Old 06-11-2007, 12:53 AM
jeepteejay
This seems great to me.
Anyone know anything about these Wilwood brakes? Any good? Replacing worn parts going to be difficult?
jeepteejay is offline
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
88 yj rear axle assembly? kp61man YJ Wrangler Technical Forum 2 02-14-2009 02:12 PM
Solid Axle Diff Cover mud n rox TJ Wrangler Technical Forum 12 11-11-2007 02:02 PM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 02:23 PM
D44 axle assembly TAMUJeep TJ Wrangler Technical Forum 0 03-03-2007 09:17 AM
