Solid Axle Diff Cover - JeepForum.com
post #1 of 13 Old 11-04-2007, 10:55 AM Thread Starter
mud n rox
mud n rox's Avatar
I'm installing a Solid Axle Diff Cover today. It has the raised fill plug on it. My question is how much fluid do I put in?? Do I go with the factory specs or does it take more? 4x4xplorer says 2 qts but thats with a Rockcrusher Cover. I'm not sure if they are the same or not. Oh yea its on a D30. I searched but couldnt find a definite answer.
2001 TJ Sport - With a little lift, some armor, four mud tires, and a few decals.
Caution: Rock and a hard place just ahead.
mud n rox is offline
post #2 of 13 Old 11-04-2007, 10:59 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Since your rear axle has been tilted back to raise its pinion angle to match the CV driveshaft's pinion angle requirements, fill it to the raised fill hole. Tilting it means the OE fill hole is lowered so it's hard to get enough gear lube into the housing. The raised hole of your new cover allows enough gear lube to be added without spilling out during the fill process.
Jerry Bransford is online now
post #3 of 13 Old 11-04-2007, 11:00 AM
robncar
robncar's Avatar
For the D30, it's 2.5 pints (1.25 quarts) according to the FSM, not 2 quarts. The fill plug is higher on the Rockcrusher / Solid covers, you don't want to overfill as the lube will be pumped out the breather tube = big mess.
FRONT AXLE ± .03 L (1 oz.)
181 FBI (Model 30) 1.2 L (2.5 pts.)
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #4 of 13 Old 11-04-2007, 11:00 AM
robncar
robncar's Avatar
Originally Posted by Jerry Bransford
Since your rear axle has been tilted to match the CV driveshaft's pinion angle requirements, fill it to the raised fill hole. Tilting it means the OE fill hole is lowered so it's hard to get enough gear lube into the housing. The raised hole of your new cover allows enough gear lube to be added without spilling out during the fill process.
Jerry, isn't the OP talking about the D30?
robncar is offline
post #5 of 13 Old 11-04-2007, 11:44 AM
Jerry Bransford
Administrator
Oops yep he is, thanks.
The front axle should be filled per the axle specs which is pretty close to 1.8 quarts. Overfilling it to the top of the new cover's elevated fill hole is just likely to cause gear lube to leak past the seals.
post #6 of 13 Old 11-04-2007, 01:14 PM Thread Starter
mud n rox
mud n rox's Avatar
post #7 of 13 Old 11-11-2007, 10:41 AM Thread Starter
mud n rox
mud n rox's Avatar
I noticed something. The Solid cover is deeper than the stock cover. It comes out farther from the axle than the stock cover. Would this make any difference in the amount of fluid in the diff?? I only ask this because I put in the 1.25 qts and when I drove it I got a weird kind of clicking noise that wasnt there before the cover change.
post #8 of 13 Old 11-11-2007, 10:44 AM
Jerry Bransford
Administrator
Perhaps it's interfering with the draglink/tierod, there's not much clearance in that area.
post #9 of 13 Old 11-11-2007, 10:49 AM Thread Starter
mud n rox
mud n rox's Avatar
I thought of that but there's no marks on the cover or drag link/tie rods.
post #10 of 13 Old 11-11-2007, 10:54 AM
04WranglerX
04WranglerX's Avatar
Yeah, I noticed this when doing mine the other day. I filled it till I could feel the oil with my finger. That's what I do at work.
04 Silver Wrangler X
Rubicon Express 4.5" SF, RE Monotubes
AA SYE, Tom Woods DS
35" Yokohama Geolanders on black rock krawlers
Dana 44 rear, ARB air locker, cromo shafts, Dana 30 front, 4.88's front and rear.
04WranglerX is offline
post #11 of 13 Old 11-11-2007, 12:32 PM
robncar
robncar's Avatar
Yep, usually a good plan, the ol' finger test. The RockCrusher and Solid covers have there fill plugs higher up though as compared to the stock covers. So, with the finger test, you may overfill.
I think I'd jack up the front end (both front wheels off the ground) and spin the front axle by hand and listen for your clicking sound to try to find out where it's coming from. You could also cycle the steering gear lock to lock. This would be easiest with an assistant. I've seen the Rubi guys speak on an issue with clearance if you tighten the fill plug too far (I use teflon tape on my fill plugs and make them "snug"). Make sure nothings rubbing on the new cover, inside or out.
robncar is offline
post #12 of 13 Old 11-11-2007, 01:27 PM
nettak
I was just wondering about doing that. The teflon tape won't cause any problems?
'03 Rubicon, RE 4.5" LA with 1" BL and 1" MML, RE Monotube shocks, 35" Nitto Terra Grapplers, Warrior Products safari rack, ORFab tire carrier w/ HiLift and gas cans, Warn M8000 winch, Warn rear bumper, Fabtech front winch bumper, IPF/Fatboy headlamps with homemade wiring harness, Ruff Stuff heavy duty diff covers, Kilby cargo rack, AtoZ rockers, Bestop trektop nx
Ain't no ghetto bling Jeep!
nettak is offline
post #13 of 13 Old 11-11-2007, 02:02 PM Thread Starter
mud n rox
mud n rox's Avatar
Thats a good idea. Will keep you posted. I guess if that doesnt work I can always put the stock cover back on and see what happens.
The new cover was installed the first of the month but the jp had to sit for a while once the problem was found (not my DD). Yesterday I pulled the new cover to inspect things. I found no foreign objects or metal shavings. No marks on the inside of the cover or the plug. The plug barely goes through and does have teflon tape on it.
Is this a Dana 30 SOLID diff cover? TJamz TJ Wrangler Technical Forum 9 10-29-2009 09:26 AM
Rockcrusher or Solid diff cover. Is there a difference? SteelBlueTJ TJ Wrangler Technical Forum 30 09-30-2009 12:15 PM
How much oil for a Solid diff cover? 1fastR TJ Wrangler Technical Forum 10 02-26-2009 08:27 PM
Solid D35 Diff Cover question hase TJ Wrangler Technical Forum 12 12-21-2008 03:21 PM
Solid Diff Cover Deal? bruker TJ Wrangler Technical Forum 14 07-17-2007 06:15 AM
