solenoid throttle hook up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > solenoid throttle hook up
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 06-11-2009, 04:05 PM   #1
Srgslaughterav
Srgslaughterav's Avatar
I was wondering what you all thought about an electrical selinoid hooked up to my throttle? So I could hit a button or a switch of some sort to bring my rpm's up and sustain at a certian point. Basically using for winch and OBA but also would like it to be used as the "third foot" as well. Or do you think I should not bother and just set myself up with the ussual bike cable method attached to the gear shiftter witch would have a locking ablitty. I am sort of undecieded as to what I want and thought I would like to hear others opinions. I can see disadvantages and advantages to both set ups. Any input or comments are welcome. Thanks
4" short arm lift, Anti rock sway bars front and rear. hard rock Front and rear bumbers, Warn 9.5ti winch,Undercover fab engine and tc skid,genright extreme gas tank, AtoZ Fabrication rocker guards, metal cloak fenders all around,JKS bar pin elminators, Viair Extreme Duty OBA system, Cobra CB, 37'' iroks on trailready beadlocks , NP231 Novak shifter tera low 4:1 with 2 low kit and SYE , CV ds, rockjock 3 front and rear dana60's with front and rear ARB with 4:88's.PSC hydro assist
Srgslaughterav is offline   Reply With Quote
Unread 06-11-2009, 04:17 PM   #2
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Bike cable it's cheap and straight, forward unlike...?
GOLENJEEPTJ is offline   Reply With Quote
Unread 06-11-2009, 04:21 PM   #3
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Yep, just use a bicycle shifter and cable, it works well and it'll be a LOT easier to make it work like you want it to. www.rubiconexpress.com/ sells a kit to do this.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 06-11-2009, 04:29 PM   #4
TJSport01
yeah the bike shifter works but if you could do it with a press of a button more power to you that would be cool and unique
Build Thread: http://www.jeepforum.com/forum/f9/2001-tj-build-thread-attempt-2-a-683648/
2001 Jeep TJ, 1in JKS Body Lift, 35x12.50x15in Goodyear Mtr's and a RE 4.5 SF with AA sye, tom woods custom cv drive shaft, tnt tube fenders w/3in flares and flush mounted led turn signals, 1in mml, cobra cb and firestik, custom rock sliders, herced, trail scars
Looking for 4.88s (R&P) for a d44/d30 PM me
TJSport01 is offline   Reply With Quote
Unread 06-11-2009, 06:58 PM   #5
RnEmOvr
Will tow
RnEmOvr's Avatar
if you have cruise they make a kit to convert that to do what your speaking of
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
FBI data shows that 323 murders were committed with rifles of any kind in 2011. In comparison, 496 murders were committed with hammers and clubs, and 1,694 murders were perpetrated with knives.
RnEmOvr is offline   Reply With Quote
Unread 06-11-2009, 07:34 PM   #6
Srgslaughterav
Thanks for your responses. I should have elaberated a little about my brain storm. A slow night at work caused me to think of this way to be unique in my so called hand throttle. Which is used for many different applications in the industry today. It is basically a little electric motor with an arm hooked up to the throttle. A little computer chip hooked to the motor and a switch or turn knob style button on dash. The knob turned to a cerntain point would tell the motor how far to push the throttle down and hold it there. When not turned on it would free wheel without binding to the existing throttle cable or foot peddal. You all are probably right! A bike cable from the local bike shop would be easy,quick and vertually fail safe. Take me like 15mins to install. But then I will have the same old hook up that everyone else has. At least I know there is a reason for everyone to have one right? Because it works! Thanks for helping me realize that sometimes basics are porbably the best way to go.
Unread 06-11-2009, 07:41 PM   #7
catsknr
I had that same idea except I was going to fab a bracket for a door lock solenoid, then just flip a switch and it pushes the throttle linkage to the desired position. Hardest part would be adjusting the solenoid so the max extension is at 1500 rpm, but if cut slots in the bracket to slide it forward or backwards it would be easier. Like you, a slow day at work, and thinking of the coolness factor.
/l ,[____],
l-L -OlllllllO-
()_)-()_)-o-)_)
Just Empty Every Pocket
catsknr is offline   Reply With Quote
Unread 06-12-2009, 04:58 AM   #8
Skyryder
I did just what your thinking.
I used the fast idle controller from a old 6..9-7.3 Ford (Int.) diesel (pre-power stroke)
I also used the same bracket that mounts it to the injector pump although it had to be bent and twisted on order to use existing bolt holes. These are extremely durable little solenoids with an adjustable "tip" that can be used to fine tune Rpm in a wide range.
My plan is to activate it when the power is switched on from my yet to be built in-dash winch control.
I know one pic is worth a thousand words, if interested I can post pics later as it's 4 AM and the house is still sleeping, as so the neighbors.
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline   Reply With Quote
Unread 06-13-2009, 01:02 AM   #9
catsknr
I would like to see some pics of your setup, should be able to get one from the local pic-a-part.
Thanks for your input
/l ,[____],
l-L -OlllllllO-
()_)-()_)-o-)_)
Unread 06-16-2009, 08:37 AM   #10
Skyryder
Sorry it took so long, been out camping, , ,
Hope this helps some.
Skyryder
Unread 06-16-2009, 09:22 AM   #11
gethin
what about using a hi torque servo from a RC car/airplane? I'd think that would work very nice.
gethin is offline   Reply With Quote
Unread 06-16-2009, 09:25 AM   #12
NotURMailman
NotURMailman's Avatar
I like it!
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfunction or uninstall themselves at any time.
NotURMailman is offline   Reply With Quote
