Soldering the copper tube of an ARB seal housing? - JeepForum.com
post #1 of 6 Old 07-20-2010, 05:45 AM Thread Starter
AlexGeorgakis
The small copper tube on the seal housing assembly of my rear ARB locker has got a small hole in it. It hasn't sheared off or anything. I've ordered a new part but I was wondering if some solder used for plumbing pipework would hold up as a permanent fix. This way I could use the repaired seal housing as a spare.
AlexGeorgakis is offline
post #2 of 6 Old 07-20-2010, 05:59 AM
Sundowner
It should hold...if it's done right. A repair-type fitting soldered in place over the damaged area will be your best bet, as it gives the solder a massive amount of surface area to which it can adhere...so it's kind of like capping a rabbit hole by building a parking lot over it. That said, 100 psi is regularly used to pressure-test household copper water lines, and I've run a LOT more pressure than that through a copper line before. You should be fine if your soldering skills are up to the task.
Sundowner is offline
post #3 of 6 Old 07-20-2010, 06:10 AM
tractor1
1979 CJ5
The most impotent part is to make sure the parts you solder are clean! Before you solder them.
tractor1 is offline
post #4 of 6 Old 07-20-2010, 06:19 AM
Sundowner
The line itself is in very good shape. A good wipe-off with a rag will take off most of the oil, and the flux itself will clean the rest of the joint. Like I said...skills.
Something you may want to do is make sure the line itself is open at a fitting, or the hot air created by the torch could blow the liquid solder back out of the repaired area. There's not a lot of expansion room in a line that small, so the heated air pressurizes quickly.
post #5 of 6 Old 07-20-2010, 06:45 AM Thread Starter
AlexGeorgakis
Great! Thanks!
I've done some copper pipe soldering before (a long time ago) so it shouldn't be difficult. I'll try it out and let you know!
post #6 of 6 Old 07-20-2010, 06:58 AM
Sundowner
Buy some icemaker tubing and practice first (1/8th soft copper).
copper , soldering , arb , locker , tube , axle , tj , wrangler
Thermostat housing seal leak 92yjwrangler YJ Wrangler Technical Forum 4 07-06-2010 09:03 PM
What would cause a spun seal housing on S35 ARB mcneil TJ Wrangler Technical Forum 11 05-21-2010 06:31 PM
Proper seal for thermostat housing Cards89YJ YJ Wrangler Technical Forum 22 02-20-2010 03:50 PM
Crown SYE kit tail housing seal 1loco2 TJ Wrangler Technical Forum 2 07-08-2008 02:53 AM
HELP! tc rear housing seal jeep75 YJ Wrangler Technical Forum 5 10-15-2004 01:26 AM
