Sold my 4-door JK Rubicon and, Bought a 2-Door TJ Rubicon - lift questions - JeepForum.com
post #1 of 18 Old 10-07-2011, 02:20 PM Thread Starter
hifiguy7
hifiguy7's Avatar
I will admit that I used my JK hard. But, the motor had to be replaced, there were differential leaks and I really felt it was time to move on. So, I sold it and bought a hot-rod SUV (Trailblazer SS). I thought that I could let go of the Jeep.
Then I came to the realization that I really missed my off-road adventures. So, I bought a 2006 TJ Rubicon. I will not miss the JK motor and am looking forward to a long life enjoying this TJ.
Now, can someone tell me in one sentence, what is the best lift kit for this?
I wheel in the NW - mud, water, climbs etc. I want a real lift - not a body lift - this will not be a pavement princess. I am thinking 3 to 4 -inches. I want to run 33's (TJ is auto tranny) - I will add bumpers, winch, rock sliders - but that is about it. I hate these Wrangler tires - I want my Mid Terrain BFG's back (Northwest Mud!!). I have heard talk of short arm vs. long arm and am also told I will need to address axle (slip yoke eliminator). I have culled through the threads and have seen a lot of discension among forum members.
If you have my same year and model, please tell me what has worked for you.
hifiguy7 is offline
post #2 of 18 Old 10-07-2011, 03:05 PM
alex211
1995 XJ Cherokee
Zone 4.25 combo lift it a good one on a budget. It's a 3" spring lift with a 1.25 body and a 1" mml.
Or go with the Currie 4" lift, one of the best short arm lifts out there.
The currie kit comes with a new front track bar, and an anti rock. Also uses johnny joint control arms. I would do a 3" spring lift and a 1.25 body lift so you can do a mml lift instead of a t-case drop. A small body lift also gives you the option to tummy tuck the jeep for much better clearance, which will require a CV rear shaft.
Savvy makes a real nice 3" suspension lift, pretty much the same kit as the currie 4" but an inch lower. I would pair that with a 1.25 body lift and 1" mml if you can afford it.
95 xj bone stock for now
alex211 is offline
post #3 of 18 Old 10-07-2011, 03:16 PM
MotoSoul
I would go with a 3 inch lift with a 1.25 body lift. The gearing isn't good, but it will be livable for the moment with 33's. Upgrade to a set of short arms with Johnny Joints(Currie/Savvy is a good place to look.) The adjustable JJ arms will also allow you to change you pinion angles when doing the lift/ tummy tuck (Undercover Fab works/Savvy have good ptions here for aluminium transfercase skid versions). You do not need to adjust your transfer case(slip yoke eliminator) as you have a Rubicon model and it is already done. You might need a longer rear driveshaft, but that would be about it.
In reality Just call up Gerald at Savvy and let him sort you out(have your credit card handy lol)
MotoSoul is offline
post #4 of 18 Old 10-07-2011, 03:20 PM
Duck Doctor
SYE is not applicable for the 241 transfer case in the Rubicon. You may want to mention your budget so these guys can provide appropriate suspension suggestions.
Duck Doctor is offline
post #5 of 18 Old 10-07-2011, 03:29 PM
Imped
Imped's Avatar
Here's your one-stop shop for suspension, armor, steering, and brakes: http://shop.savvyoffroad.com/
There's more to it than "lift and tires."
OlllllllO
IndyORV
Imped is offline
post #6 of 18 Old 10-07-2011, 03:30 PM
biffgnar
biffgnar's Avatar
True as to SYE. But a new CV driveshaft still maybe necessary.
biffgnar is online now
post #7 of 18 Old 10-08-2011, 02:03 AM Thread Starter
hifiguy7
hifiguy7's Avatar
Thanks for the input. I don't really have a budget yet. Definitely will never put a body lift on my Jeep. I had a 4-inch lift on my JK (Superlift with Bilstein 5100) added 35's had to re-gear to 5.13. It was a good setup. I wheel with a friend whose dad has a TJ with 33's. It really seemed to be right for the size of the chassis. He had a 4-inch long arm kit. I think I want to stick with short arm.
I will check out the guys at Saavy.
hifiguy7 is offline
post #8 of 18 Old 10-08-2011, 07:27 AM
MotoSoul
I do have to ask why are you so against body lifts? A proper 1.25 inch body lift allows you to run the best tummy tucks and raise your gas tank without major modification. You can't even really notice the difference over stock. Now if you just mean the 2 inch and above then I completely understand.
MotoSoul is offline
post #9 of 18 Old 10-08-2011, 07:38 AM
Imped
Imped's Avatar
Body lift on JK = pointless
Small body lift on TJ = very functional
OlllllllO
IndyORV
Imped is offline
post #10 of 18 Old 10-08-2011, 07:42 AM
MotoSoul
You know I never even considered the fact that it might be due to him coming from a JK. I would think a body lift on a JK would only be benifitial if you were trying to mod a TJ gas tank into one.
MotoSoul is offline
post #11 of 18 Old 10-08-2011, 07:09 PM Thread Starter
hifiguy7
hifiguy7's Avatar
I am coming from a JK. I thought there was no benfit to a body lift, other than your rig looking like it is lifted without being lifted (wonder bra lift). I put it in the same category as the guys that use 22-inch rims on a JK.
By your implication, is there a wheeling benefit to a body lift?? What do you mean when you say tummy tuck? I am here to learn and would appreciate a lesson here.
hifiguy7 is offline
post #12 of 18 Old 10-08-2011, 08:29 PM
DavidC
My $.02
OME 2" shock/springs( go HD on the springs)
Or BDS 2" shock/springs( have been using these for 5 years)
All 8 Currie CA's. (have been using these for 5 years)
Currie extended bump stops.
Currie 1" body lift.
Currie Antirock.
Very capable on/off road system.....
2012 JKU Rubi,Auto, 4.10's "takes a licking and keeps on ticking"
99 Sahara D30/44 w ARB's and 4.10's, Warn 9.5TI,AA SYE & Wood's shaft,Raingler nets,Jeeperman trail skids,Warn gas tank and steering box skid's, BDS 2" springs, Currie control arms,32" MTR's,AEV Bridger wheels, custom made tire carrier bumper,Dynomax cat back JKS quicker disco's.PSC Trail Cage,Banks header,LiteDots.PSC Trail Corners.
92 CDN M101 trailer, 33" TSL Swampers,camo paint. Original camo tarp.
DavidC is offline
post #13 of 18 Old 10-08-2011, 08:38 PM
DavidC
By your implication, is there a wheeling benefit to a body lift?? What do you mean when you say tummy tuck? I am here to learn and would appreciate a lesson here.[/QUOTE]
Body lift= more clearance for you wheels.Lifting tub higher from frame. most folks will tell ya 1.25" or less is best. I've seen some knuckle heads with 3" BL's and no way to shift into 4LO due to shifter binding.... flame suit on.
Tummy tuck= transfer case skid plate that is more flush with your frame rails thus giving you more clearance. Issues with this are you may need to modify your exhaust and drive line to have it work right.
DavidC is offline
post #14 of 18 Old 10-08-2011, 09:05 PM
Imped
Imped's Avatar
What's more evident? Flat belly ("tummy tuck") or body lift?
OlllllllO
IndyORV
Imped is offline
post #15 of 18 Old 10-09-2011, 12:31 PM
Bluesdude
3.5" RE lift
I have a 2004 TJ Rubicon. Had a 3.5" Rubicon Express Superflex lift installed, added Bilstein 5100 shocks, and am now adding a RE CV driveshaft and RE3783 Upper adjustable rear control arms to get the pitman angle just right. Running BFG 33" KM2's on my stock 16" moabs w/ spidertrack spacers. So far love the look and the ride!
Todd
Bluesdude is offline
Bought a 2012 2-door Rubicon today sdr0303 JK Wrangler Technical Forum 8 09-04-2011 07:49 PM
04 tj rubicon half to full door conversion questions awalp TJ Wrangler Technical Forum 18 04-17-2011 08:08 AM
Sold my 01 Sport and bought an 05 Rubicon! zerocool333 Wrangler General Discussion 3 01-10-2011 06:40 PM
Just bought 2009 2 door Rubicon - did i pay too much? allergyking Wrangler General Discussion 17 12-08-2009 10:49 AM
Looking to buy 4-door JK Rubicon in June. Had some questions Totsie7944 JK Wrangler Technical Forum 14 01-28-2009 02:22 PM
