Soft Windows Removing Scratches - JeepForum.com
post #1 of 11 Old 11-09-2007, 09:13 PM Thread Starter
tj99
tj99's Avatar
Just bought another Jeep, this one's for me! Got it reasonable partially because the drivers side upper is trashed from a break in. Won't be able to replace the top for a while so I'm trying to make do. Can't hardly see out of any of the windows.
Did a search and found suggestions for Maguires products and a Mother's Polishing Ball. Is that just regular Maguires polish or something special for plastic?
Thanks!
1998 2.5L 5Spd - Sold
1999 4.0L Auto - Mine
2010 JKU - Sold
2014 JKU - Wifes
tj99 is offline
post #2 of 11 Old 11-09-2007, 09:39 PM
McJeepz
Try using Plexxus before going to any polishing type compounds or wheels etc. I've performed miracles reviving old plastic softop windows and motorcycle visors etc with it.
Comes in a can like furniture polish - try bike shops to find it or maybe google it.
It works wonders
Rob
McJeepz is offline
post #3 of 11 Old 11-09-2007, 09:48 PM
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
I have this stuff. It works really well.
http://www.4wd.com/productdetails.as...0&partID=10582
We save dogs:
JBWood05TJ is offline
post #4 of 11 Old 11-10-2007, 08:16 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
It works wonders
Rob
X 2 on that.That is great stuff!
TheBoogieman is offline
post #5 of 11 Old 11-10-2007, 02:56 PM
three3fitty
I use the Meguiars plastic X. I got alot of the scratches out, and some of the yellowing i had in my windows. i'm very happy with the results.
Red 1998 Jeep Wrangler SE I4, 5spd - 2 HELLA 500FF lights in the front bumper. 4 KC Daylighters on a smittybuilt light bar. ATK rebuilt 2.5ltr.
three3fitty is offline
post #6 of 11 Old 11-10-2007, 03:20 PM
Hesher420
my $.02
I use Flitz on my jeep windows, jeep headlight lenses, cycle light lenses. The stuff is great when used with a mothers ball and LIGHT pressure.
Hesher420 is offline
post #7 of 11 Old 11-10-2007, 03:56 PM Thread Starter
tj99
tj99's Avatar
I picked up some Maguiars PlastX today and it does help.
Almost got one of the Mother's polishing balls but decided to try by hand first.
Thanks everyone!
2010 JKU - Sold
2014 JKU - Wifes
tj99 is offline
post #8 of 11 Old 11-10-2007, 05:27 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Now that you're up on polishing out scratches, keep them from forming by not rubbing on them when they're dirty (hose the dirt off first) and NEVER using paper towels on them. Paper towels are made from wood pulp which leaves millions of little scratches every time you use them on plastic windows. After a while those scratches turn the window opaque and then it starts turning yellow.
Jerry Bransford is offline
post #9 of 11 Old 11-10-2007, 06:17 PM
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
Okay JB, enlighten us......what should we use to clean the windows? I am guessing newspaper is out too. Also, I know you are not supposed to use windex (ammonia based cleaners) on windows with film tint, but what should we use on OEM tinted soft windows?
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build thread
dogbluedrummer is offline
post #10 of 11 Old 11-10-2007, 06:39 PM
Rocky529
Rocky529's Avatar
Terry cloth or micro fiber towels are your best bet.. never wipe them when dirty/dry.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #11 of 11 Old 11-10-2007, 07:09 PM
McJeepz
Use the fake sheepskin mitts and lots of water to get the majority of the dirt off - rinse the mitt thoroughly and often during the process - then plexxus or whatever. You windows will last years longer.
edit: and yes, the microfiber towels are worth their weight in gold.
Rob
McJeepz is offline
removing scratches from windows...? fishmanwill YJ Wrangler Technical Forum 3 12-18-2009 05:41 AM
Removing Scratches/Scuffs from the Plastic windows T_Bone TJ Wrangler Technical Forum 2 11-07-2009 12:33 AM
Removing soft top windows... bjjfoshizzy TJ Wrangler Technical Forum 6 02-12-2008 07:45 PM
Scratches on soft top windows (yes I searched, this is a bit different) RAAB3485 TJ Wrangler Technical Forum 6 02-08-2006 07:23 PM
scratches on soft top windows 92redragtop YJ Wrangler Technical Forum 4 10-21-2002 12:06 PM
